6080 Brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Brakes
    Posted: 04 Nov 2018 at 3:02pm
Looking at a 6080 with 6300 hrs on her. Fairly nice tractor kept in shed. Brake pedals go to the floor! Owner has passed away so I have no one to ask questions about its history. Don’t have a book, what is involved replacing brakes?
wlambs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 3:58pm
first check to see if any fluid in brake system. it uses hyd.oil instead of brake fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:18pm
There are bleeders on planetary if it is out of oil.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 8:29pm
I suspect that as well, found dads 6060 service manual and it covers the 6080 also. We have never had brake issues on dads 6060 so we are in new territory here. Kind of time sensitive as we need to let the owner know soon if we want to purchase it.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 7:48am
Current user said they have been out for 3 years. Said he refills the reservoir when he needs to use it, but it doesn't last long.
Said he can't find any leaks though.
Charlie
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 8:12am
Did he mention what he refilled it with?  If it's like the other foreign tractors that have fluid brake systems instead of mechanical linkage, then it probably leaks internally into the rear end housing.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlambs Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 11:22am
my 6060 would leak all fluid and had to put new o rings in the brakes system. they can be ordered though agco
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 12:31pm
Check the line between the resivor and the master cylinder. Mine was cracked where you couldn't see it without 5 mirrors and 3 flashlights. Put new hose on and no more Hyd oil loss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 12:32pm
He used the AGCO Spec'd fluid from dealer.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 12:33pm
Near the master cylinder just above the hose barb. Hope that's all it is .
