1938 model b steering
siev2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote siev2000 Quote  Post ReplyReply Direct Link To This Post Topic: 1938 model b steering
    Posted: 30 Oct 2018 at 8:16pm
So I picked up a model b for restoration as a high school ag class project. One thing I am stumped on........it steers backwards! What is going on folks? Turn wheel right the wheels turn to left???
Thanks
OhKen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OhKen Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 9:05pm
C and B steering boxes steer opposite of each other . My guess is somebody replaced your B box with a C box , not knowing this .
59f100292 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 9:06pm
Any chance it’s a C with a B front end? Sounds like it has a C steering gear box in it if it’s for sure a B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote siev2000 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 9:32pm
How would I tell the difference?
I do see the gear box is not fully bolted up tight, so maybe there something to this idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote siev2000 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 9:39pm
supposed be a 1938, serial number 917, no starter hand brakes, wide front end.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 10:40pm
The tractor serial number should include a letter for the model.
It might be that the B and C shop manual can help you identify the parts.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 6:01am
Pictures, pictures and more pictures. After 80 years and B C parts being interchangeable unless you know the slight differences in B and C parts it is hard to tell what you may have. The B steering box has a shorter out shaft with a constant spline. The C steering box has a longer out shaft that has a larger diameter spline that is not constant exact splines. They can bolt up tight to the torque tube because both the B and C uses the same torque tube. This is only one of many slight differences in parts that will interchange.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 7:44am
The Arm on a B box points down. A C arm points up. Makes the mismatch you describe by using a C box on a Arched Wishbone B Front axle used on All 1938 Bs.
     Any B Gemmer or Ross box will correct the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 8:07am
How Correct a 38 are wanting your Highschool project to be. I helped a friend do up a Early B like yours. #751.  I have a extra pair of the correct F&H Cast Iron front wheels for your early 38 B if yours don't have them.   Being the 816th B off the assembly line it came with 3 piece rear rims bolted to the wheel with 2 3/4 Bolts and 2 3/4 eccentrics. They may be long gone.
    Correct rear tire size should be a 8-3 x 24.
     By requesting a copy of a early B parts book as a guide for a accurate restoration would help you tremendously .  Your B should NOT have a metal seat back. It was wood padded and covered with canvas
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 8:32am
Thank you  Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote siev2000 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 9:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 10:14am
OK, I'll bite. I had never heard of this issue. But I am trying to get my head around how it would feel to attempt to drive a tractor that has been set up like this!:) My guess is that eventually it might become OK in your brain that it responded back wards?? Kind of like getting off a Allis WD series with the hand clutch and getting on a John Deere with the opposite working hand clutch???
I Think you should find the correct steering box and add that to the list.
Yes we need tractor pictures of the project too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 11:00am
This might help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 11:05am
Looks like a B steering box from that angle. Could you take a picture showing the linkage from the front to the steering box including the front axle?
Edited by Dick L - 31 Oct 2018 at 11:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 1:02pm
like Dick said........ look at the front end linkage.. Does this gear box have a long rod that connects under the radiator, or does it connect to the left front wheel king pin area ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote siev2000 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 10:30pm
front left king pin connection
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 10:47pm
In the summer of '68 I worked as a helper millwright, during change over. Some of the fork trucks there steered backwards, to go right you turned the steering counter clockwise.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 6:55am
I will resize your pictures if needed so we can help figure out what is going on. A side picture of the tractor might be a help.
