185 Block Heater
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: 185 Block Heater
    Posted: 24 Oct 2018 at 5:38am
Want to put a block heater on my 185 where does it go on the engine?
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2018 at 6:10am
Mine is @ the right rear above the starter
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2018 at 6:13am
Gary,
If you send a email or cell number I can send a photo if you need one later this afternoon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2018 at 11:44am
Originally posted by Gary(VA) Gary(VA) wrote:
Gary,
Thanks email is gburnett570@earthlink.net
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2018 at 12:37pm
Here's an image of where the block heaters usually are.  I am not sure all blocks have the same freeze plug and bolt holes in the water jacket.  My 7000's 301 is in the rear-most freeze plug/flange.  This one is in the center.
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2018 at 3:52pm
Hurst photo is where mine in also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 7:46am
So take out the freeze plug and put in the heater? I found a new AGCO block heater on ebay and ordered it so I guess I'll see when it gets here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2018 at 7:49am
Make sure you have the tapped holes if you are using the one that has the bolt-on flange.  If it doesn't have 2 threaded holes, you can use one that will fit into the freeze plug and tightens using a screw through the center and a wing on the back to pull it tight.
Hurst
5800 Hours
This page was generated in 0.118 seconds.
