Gleaner Cab Kit
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner Cab Kit
    Posted: 18 Jul 2010 at 8:56pm
I'm going to be putting a new liner kit in my K2 cab. I've seen 3 different manufacturers for the two piece kit. Has anyone done this to their cab? Where did you get a kit, and how was fit/quality? Thanks.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 9:24pm
Hope someone replies, I would like to do that to my K also.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 10:13pm
My F2 needs it to but what's one more year?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 12:07am
My dad did it to a K 20 years ago.  You have to remove all the old stuff well, then you need to drop down the fan to put the new padding up.  He did not buy the padding as a kit, he bought some foam rubber and cut it to shape.  Still looked good many years later.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 10:01am
I got a cab kit for my 7050 that fit real good. From K & M manufacturing in MN. Price wise I don't know as I didn't shop around and that's who we dealt with when I worked at the CaseIH dealer. They are all over priced for what you get.
Wink
I am a Russian Bot
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 1:36pm
got mine from shoup for the m2- will be the same kit- fit great- scrap the old stuff out , put the pieces in first wo glue to see how they fit- then go really slow putting it in w glue- i did mine about 1 foot at a time- then more glue- then 1 more foot etc
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 8:40pm
WHAT IS THE BEST GLUE FOR THE JOB, WILL BE DOING A BLACK 7060 SOON.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 10:22pm
Thanks for the input all. I ordered the interior kit today. It is made by FEHR Cab Interiors. Check out their web site, quite impressive what all they have available and will custom make. Once I get started I'll try to post some photos.  Jim
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2010 at 10:52pm
i put some good carpeting in mine, easy to clean and so far has held up fine. get some that's easy to look at! also the carpet i put in my "G" combine 15 years ago is still there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2010 at 6:40am
i used the 3m adhesive from napa
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2010 at 6:57am
I got my K2 kit from Frehr along with their 3M adhesive spray can.  One 3M can should easily do one cab.  Procedure for installing the kit:
1. remove the seat & its frame at the floor.
2. remove the old torn upholstery pieces by hand.
3. using a 4" grinder with a wirebrush head, remove any foam that is still stuck.
4. size all your new pieces of foam to your rear wall & ceiling.
5. make sure you allow for an overlap at the ceiling/wall corner.
6. You do not need to remove the upper fan console.
7. When ready to begin adhesive, spray both the back of the foam & the surface.
8. I started at the top of the rear wall and worked toward the floor with new foam.
9. In doing the ceiling, start with foam from the wall working toward the upper console.
10.  Don't glue the excess foam that folds into & under the upper console area.
11.  Clean old floor out, rust proof with paint, then add new flooring over.
12. Re-install the seat & its frame.
13.  KEEP MICE OUT, by cleaning out all of the leftover grain after harvest each year!!!
