226 Pan Gasket
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: 226 Pan Gasket
    Posted: 15 Jul 2010 at 12:46pm
Who makes the best oil pan gasket for the 226?  Need one!
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 8:26pm
felpro  makes a good cork gasket and i will give u a bit of advice if u are putting it in an engine still in the tractor roll your from and rear main pieces in a tight circle and hold like that with a rubber band then soak them in a cup of water overnight. this makes them swell alittle and more pliable. then position on the pan and on the outsideof the pan stick needle in the gasket to center it. put the pan and gasket up and bolt down, pull your pins and its all good.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 8:38pm
Now that sounds like a good process, josh. Oughta work on any of those gasket sets. I've seen the "curl overnight" suggestion before but you've added a couple of good ideas.
WC, CA, D14, WD45
