Oil filter base to block gasket |
Post Reply ![]() |
Elo76 ![]() Bronze Level ![]() Joined: 18 Jun 2018 Location: Ellwood City Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Jul 2018 at 10:57am |
Have some leakage coming from here and was looking to replace the gasket. Have been having trouble finding just that gasket without buying a whole kit.
Can RTV gasketmaker/sealant be used here?
Stan R ![]() Orange Level Access ![]() Joined: 03 Dec 2009 Location: MA Points: 991 |
or make your own gasket?
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3837 |
I failed ESP class thus it helps to know what you are working on? ![]() Assuming its a WC, WD, 45, B or C or similar engine oil filter because they are the ones prone to leaking,, Leave the blue glue in the tube, only takes about 1 minute to make that gasket from a sheet of rubberized cork using the base as a template. Most of the time you will find that the base is bent where it mates the block. The fix for that is running it over sandpaper placed on a fat surface
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53849 |
Easy way is to run the plate against a 200 grit belt, on a bench top belt sander, or hand file, if you are old school. What generally happens is the old cork gasket gets leaky, then the bolts get over torqued, when somebody tries to tighten, to stop the leak. As Butch says, cut a gasket, easy peasy...
Kurzy ![]() Orange Level ![]() Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Howdy Elo76, I don't use cork, seems to leak. I use a plastic top from a gallon ice cream top. Cut the gasket out of that and I had best of luck! Kurzy
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2660 |
When I redid the motor on my WC, I took the filter assembly off and you could see someone made the gasket out of an old old old Corn Flakes box, you could tell because it was the part of the rooster. Lord only knows how long that cardboard gasket held. I made the replacement out of the grey, 1/8" gasket material.
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
Agco #70233228 Gasket 2.94 Stiener # acs2397 3.65
Burgie ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Make sure the base is FLAT and make a gasket out of THICK cork material.
"Burgie"
Rog NCWI ![]() Bronze Level ![]() ![]() Joined: 02 Jan 2018 Location: Aniwa WI Points: 46 |
I used JB Weld and filled in the cavity and then filed every thing straight. Purchased some gasket material form a auto parts store and bolted it up to he block. Has not leak since.
Edited by Rog NCWI - 18 Jul 2018 at 8:38am |
squirt239 ![]() Bronze Level ![]() Joined: 12 May 2017 Location: Brownsburg, IN Points: 69 |
I have an extra one I'll send you. Private message me your address, or you can email me at info@havlinsfirearmsfinishing.com. I'll send it out in the mail.
Post Reply ![]() |
