What Allis has 34 inch wheels
CTALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Topic: What Allis has 34 inch wheels
    Posted: 13 Jul 2018 at 4:28pm
Looking to find out what model Allis came with 34 inch power adjust wheels and will fit on a D17.
thank you,
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 5:07pm
D19 and 190xt also D21 mostlikey more
ldogfarm View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ldogfarm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 5:26pm
6080 but not sure they will work on a D17
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 6:15pm
6000 series will work but I believe the center hole needs to made slightly larger. As far as I know that's the only models that will fit. D19-hundred series and larger used cast centers that clamped to axle shaft.
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 10:03pm
I put 16.9 X 34 on my 180. The rims were cast iron rims from a 6080. Traded my 18.4x28 for the 16.9x34. I bought longer grade 8 bolts for the cast rims. Have had them on for at least 5 years. They were like new tires. We use the 180 for gathering maple sap in the spring and the larger wheels makes it good with the 250 gallon stainless tank for the rougher ground in forest.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2018 at 10:40pm
6080 is the only choice that I know of, I have a set on a 175D.  I would like to find 8 on 8 steel centers for 34" power adjust rims, but have had no luck. 15.5 x 38 would probably be cheaper and easier to find for a D17...and plenty big enough.
ALLIS EXPRESS!
This year:
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2018 at 12:20am
I have 20.8x34 on a 7000. Makes a smooth riding tractor for haying.
