180 diesel barn find - wont start
allispicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Topic: 180 diesel barn find - wont start
    Posted: 08 Jul 2018 at 10:51pm
I recently bought a 180 diesel that was parked running in a barn back in 1995. It cranks over, but wont start....not even a little smoke while cranking. I loosened the lines on the injectors, pumped the primer no luck. The pump has fuel in it, the filter is full. I can't even get fuel to come out of the loosened the injector lines. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 12:15am
at the least it sounds like metering valve is stuck.Hopefully it's not been that long with biodiesel. If the tractor is worth keeping, line up timing marks and take pump off for freshening up.Likely won't need hard parts, just cleaning and seals.If bio....I can't say.If you could get it running, you'll probably be pulling pump in near future anyway.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 1:10am
did you pull the shutoff  knob out? Just asking a simple question.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 5:59am
I've seen that be the problem several times especially at auctions when guys not familiar
with the 180 and 185 diesels are starting the tractors.Good theft prevention feature though just leave the fuel shut off in when you stop it(LOL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 6:53am
The pump knob is pulled all the way out. Looks like I'll be pulling the pump off.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 7:34am
very common to have plungers and metering valve stick in these Roosa pumps when they sit a long time(not so long with poor quality bio) but 1995 was before bio-diesel issues began. Its just likely all gummed up with varnished up old diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispicker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 10:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 8:43pm
have someone pump the primer as you turn over the engine.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 7:08am
NICE!
This page was generated in 0.146 seconds.
