Allis Chalmers 6140 runs normal today, hot tomorro
ctmay20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctmay20 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 6140 runs normal today, hot tomorro
    Posted: 21 Jun 2018 at 8:32am
I have an Allis 6140. The Japanese Engine. Yesterday I moved bales with it for over an hour, it ran normal operating temperature entire time. This morning I ran it for about 10 minutes and temp gauge spiked and steam came out of the over flow line. This is becoming common. I have blown out and washed the radiator, let the engine run with radiator cap off to remove any air in the lines, coolant level stays the same, no white smoke out of the exhaust and engine oil is normal. Could it be a bad radiator cap? It just has me baffled.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 8:40am
My first guess would be sticking thermostat.  id start there if you have already cleaned radiator.
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 12:20pm
I agree on thermostat, if only took ten minutes I would say no water circulation because of thermostat. Leon
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 9:22pm
Yup thermostat
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
This page was generated in 0.140 seconds.
