Planter plates
SD Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Topic: Planter plates
    Posted: 04 Apr 2018 at 3:35pm
I am in search of a set of 4 planter plates, #310922
Thanks In Advance
Warren
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 11:04pm
Is this just a normal corn plate? If so just get the adapters and use JD plastic plates that you can find easily.
Edited by DanD - 04 Apr 2018 at 11:05pm
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 7:04am
Bean plates
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 9:42am
https://goo.gl/images/UnsgLK
You need a set of these...then get JD plastic plates. Available from places the sell plates like Lincoln.
Edited by DanD - 05 Apr 2018 at 9:43am
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 1:27pm
Yes there are beam plates
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 2:42pm
Just a warning - these were the old 70310992 bean plates designed for the old Hood type huge soybean seed.  They are not acceptable with todays small soybean seed. In order to get the desired seed rate one has to have the largest sprocket available on the front and the smallest on the back.... This turns the seed disc so small it 'hill drops' the seed  then skips then again plants 4-6 beans in a short space.   As suggested use the soyb 2 or soyb3 for 15" rows and the adaptors of course..
