Wd 45 diesel.
Bradleytrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 diesel.
    Posted: 04 Mar 2018 at 10:00pm
Put a coil, gas, tire and wheel,and a hot battery in started and drove the tractor today. Donor engine put in the shed. Dad and I came up with a plan to see if we can fix this issue of liner drop and blocks cracking in the 230 diesel engine.
Edited by Bradleytrench - 04 Mar 2018 at 10:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 10:17pm
I also want to thank everyone I talked to at the Lathrop Swap Meet. I had a good time visiting with everyone.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 10:46pm
what is the gas engine?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 7:25am
It's not a matter IF it can be fixed. It's only a matter how deep your pockets are and how much you want to have invested in it. Peanut butter fixes do NOT work on a BD230.  Send the block and head to Nevada Ia and you get back usable parts in exchange for $$$$. While that is going on you send the pump and injectors out for repair and order the  gasket set, and overhaul kit. Set  aside 7K. You may have some left over but better than budgeting 5K and finding out it wasnt enough!!
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 9:25am
Hey bud, keep the pics and updates coming on this project.this will be a fun thread to watch and keep up with.I'm green with envy, you get to work with the "master of the budas" on getting one of these old girls brought back to life.Should be a fun project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 10:27am
I understand. After looking a the block where the ledge is, I have determined that this engine will fail due to liner movement. I have a good block to start with. I'm going to use modern diesel technology to see if I make make a 230 live and not have head gasket failure, liner drop, and junk block. I have made some calls to different places to see about parts. So far it looks like mine and Dads (Don MO) idea might work. Going to take some R and D to get where i want. But I think it'll work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 11:14am
Be sure to post the results. There was a company in L.A. IIRC that produced custom sleeves with an oblong flange to combat the sleeve movement. I don't remember the name, just that I'd have gone that way when I did mine.
Edited by Brian Jasper co. Ia - 05 Mar 2018 at 11:15am
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 3:32pm
 Sounds like you have a good inside source for help. Leon
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 9:35am
Not to worry guys my son is very good with a wrench in his hands and I can let him in on the ways of the WD45's. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 9:39am
Well heck if Ida known your were Don's son I woulda kept my trap shut, LOL
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 9:57am
I'd like to know also and whats your plans for the gas engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 8:27pm
The gas engine will probably stay in it for awhile till I build the diesel. I might make a WD 65 out of it for awhile that way I can pull a plow in roadgear.
Edited by Bradleytrench - 07 Mar 2018 at 8:28pm
