Injection pump Ed?
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Injection pump Ed?
    Posted: 06 Dec 2017 at 10:12am
Bosch pump on R52 with Cummins. Throttle shaft is stuck at wide open, combine runs at idle. Whole pump need to come off?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 10:16am
sounds like it should be taken off and looked over. That doesn't sound like a simple fix on the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 10:33am
How are these timed? What's your turnaround time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 11:25am
a week or 2 turnaround on something that is needed to finish farming. Timing of the Deutz can be complicated. Best to ask someone local to time it, unless this newer one has a timing pointer on the pump hub. If so, then a piece of cake, turn it until the hub mark lines up with the pointer. Older Deutz engines had to be spill timed, since they had no marks on the pump drive hub. The hub is keyed, and can be taken off, so it can be left in the drive gear, then mark the housing in relation to the mounting plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 11:47am
Keyword in my post is "Cummins "
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 12:39pm
DUH! Pin timed, very easy!
This page was generated in 0.101 seconds.
