R72 question
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Topic: R72 question
    Posted: 22 Oct 2017 at 8:32pm
Why wont the bolt on the torque sensor stay tight on my rotor? Everybody l've talked to says don't put lock tite on it, but it's gettin old tightening it up every couple hours.
Thanks.          Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:55pm
How many ft. Labs. Of torque are you putting on it? If I remember right, it is a lock nut. May need replaced.   MACK
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 10:02pm
I've never heard of that happening. My guess is that you have something wrong inside the torque sensing hub, like maybe broken ramps or something. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 3:02pm
I don't know how many ft lbs. I just tighten it as tight as l can get it. Dad's R52 has the lock nut but the 72 has a bolt with a grease fitting in the end. Everything inside is in good shape.
