PUTTING ALT ON D-10 III
BV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BV Quote  Post ReplyReply Direct Link To This Post Topic: PUTTING ALT ON D-10 III
    Posted: 21 Jul 2017 at 3:24pm
What do I need to do to put a 1 wire alt on my D-10, use the hot wire that's running to gen now for the alt or what? thanks again
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 4:09pm
That would work. You can go with a one wire or a three wire. One wire would be as you said. Just ensure the battery is negative ground, the ammeter is 60-0-60 ( or change to a voltmeter), and the wire from the alternator is 10 AWG or heavier. 8 AWG would be better.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 4:37pm
The hot wire from the generator goes to a voltage regulator or cutout. You don't want that in the alternator circuit. The hot wire from the alternator should go directly to the new 60 amp ammeter with the same size hot wire then going to the battery connection generally at the starter solenoid post that is connected to the battery. Most all alternators are negative ground which might require some battery and ignition coil changes.
The one wire alternator has to be spun fast to get it to start charging then so long as the engine isn't stopped it will charge down to low voltage. The two wire connection applies a switched voltage to the internal regulator to get it to start without being spun fast. Could come off the accessory circuit of a replacement ignition switch or from the ignition circuit. When it comes from the ignition circuit it needs a diode or series resistor to prevent the alternator back feeding the ignition circuit to prevent the engine from shutting down. That resistor can be an alternator indicator dash lamp.
10 gauge from the alternator power will limit the maximum charging current to about 35 amps, it does that on my gas 4020. I used silicone insulated wire so it can handle being hot. 6 or 8 gauge would allow faster charging.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 6:21pm
Delco 10SI alternator, with a double pulley, smallest you can find, reverse oem bracket, and cut the generator's bottom bracket, to line up the belt.  And a hot wire, to run to the ammeter...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 7:00pm
Go with a CS121. It's smaller. Probably easier to find a one-wire version too.
