190 XT Parts Wanted
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT Parts Wanted
    Posted: 28 Jun 2017 at 3:46pm
I just purchased a 190XT Diesel that had a bad non repairable injection pump. I just happen to have a good pump. In putting the pump in and hooking up the lines, I noticed that one of the previous owners had changed the fuel line to the filter to "air brake" flexible hose. They had also taken both sediment bowls out of the system and put in valves at the bottom of the tank. I have talked to several mechanics that thinks it is a bad idea. So I am looking for someone that is parting out a 190Xt that I can get the bowls and the line up to the filter. The hand primer pump is also gone if someone has that too.     Thanks
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 4:49pm
the sediment bowls are a standard item. I got them from TSC. just get two of the WD45 bowls. the fittings are standard off the shelf compression fittings Mine came from the locxal hardware store. get them in the brass section.
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 6:36pm
I have other diesel tractors and equipment that have one fuel filter and no sediment bowl. I can see the sediment bowl on the gas engines but is it that important on the diesels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 7:04am
It is on mine it sits outside and always has water in both of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2017 at 8:34am
I have sediment bowls on my diesels
This page was generated in 0.062 seconds.
