Bio-diesel
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Topic: Bio-diesel
    Posted: 23 Jun 2017 at 10:11pm
Anyone else had problems with bio-diesel causing rust in the fuel tank?  Any solution other than to avoid bio-diesel at all costs?  That's the advice I get from other tractor owners locally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 10:38pm
My 220 and F2 (the worst) had bio one winter.....NEVER AGAIN!.That crap is only ok if using equipment daily. Will gladly pay the extra for straight diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 5:43am
Ok, I have to ask...
HOW does bio-diesel create the rust ?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:09am
probably the acids and moisture in the fuel?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:01am
We used it in our generators one year. Rust didn't seem to be a problem. Algae was a huge ptoblem, though.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:33am
It caused rust in my 220 and algae in my Vista G1000. Still fighting the rust after 5 years without using bio.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 8:37am
It's like ethanol gasoline it draws moister out of the air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 12:44pm
Not one problem in my D17D, however, not all bio diesel is the same. When it's made from waste cooking oil and animal fat it's going to be a problem gelling in cold weather. There is also more entrained moisture in it. The bio I'm using is soy based only. Soy based doesn't have the gelling problems or the moisture fat based does.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 1:05pm
Brian that must be what I get from my supplier.  I have never had a problem of any kind, of course I insist on Premium #2 diesel.  Cant imagine how diesel fuel/oil would cause rust.  I've been a lot of labs during fuel testing but not in one testing bio diesel.  The only thing I can think is fuel being delivered with water in it or condensation on the inside of the fuel  tank on a hot humid summer day.  You gotta have those Pre Vent caps on those fuel tanks to cut down on that problem, also best if they are painted white and labeled diesel fuel.  Wonder how many of these guys have had their supplier "stick" their tanks using water paste?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 2:07pm
Back around 12 or 13 we had rampant gelling issues on new 6.7 Fords. I made some calls and found Key and Heartland co ops only blended soy based bio. When I instructed my customers to stop using convenience store diesel and go to the co op for fuel, the gelling problems ended.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 2:59pm
 I've used Bio and like it but does come with some problems.   winter time gelling can happen and especially tractors seem to have trouble with rust forming on the inside of fuel tanks.    That being said; i still use it at the proper time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:05pm
Bio diesel attracts water. algae lives in the water, and acidifies it, causing rust.
Back away from bio diesel, slowly, and make the sign of the cross...Wink
