D17 Hydraulics
stroketech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Topic: D17 Hydraulics
    Posted: 07 May 2017 at 7:53pm
Hi everyone. I have a D17 Hydraulic question. Until now the oldest tractor I've had is a Series IV D17 with full hydraulics. Now with the 1962 D17 I have I need some help on what hydraulic cylinders to use on my disc and plow. Am I correct in the thought on the older style that the hydraulics lift the cylinder then just releases pressure to drop? What kind of cylinders will I need to buy for this tractor?
Thanks, Jon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 9:26pm
You should post WTB in the classifieds and a LOT of people will come to your rescue.  They are HIGH pressure and LOW volume, vs everything else today which is LOW pressure and HIGH volume.  GOOD LUCK!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 9:29pm
I'm looking on information about the difference and what I need. Not looking to buy yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 9:30pm
You need a hi pressure cylinder. One that screws to gather not bolted to gather.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 9:41pm
And it's just a single hose cylinder correct?
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 10:26pm
Correct on the single hose. When I was using my D17 more I'd just remove the down hose and replace it with a breathing filter. So far it's worked well.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:57am
correct you need a single acting cylinder or do like play farmer. (as long as you get a good one that the seals on the piston aren't leaking or you blow oil out the breather when you full stroke the cylinder).
a small bore cylinder is good for the allis hydraulic system, a large bore cylinder would work but take a long time to lift your implement.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
