corn seed
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Topic: corn seed
    Posted: 18 Apr 2017 at 5:57pm
who plants and conventional seed and what sprays can you use
and how does it yeild next to RR corn
and what is the output cost vs other
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 6:51pm
We do all conventional corn because we sell to distilleries...Use corvus and love it...We work the ground still and spray right after it's planted.clean fields every time
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 7:02pm
We grow Viking and titan pro yield is very good if not better than the high dollar dekalb we plant most years..
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 6:40am
There are dozens of sprays for corn, depending on timing and weeds to control. With clean fields, good seed, and good fertility, you get good yield. Sharpen your pencil and see what you get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:54am
Non GMO corn is cheaper to buy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:56am
And spray, treatments, insecticide for non GMO corn is expensive to buy.
That's why I said sharpen your pencil.
Edited by Tbone95 - 19 Apr 2017 at 8:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 10:05am
Tbone....Yield drag on RR corn is about 5% compared to non GMO...If you do RR corn and beans then you have to add something different to your bean chemical to get volunteer corn not to mention the immunity to weeds that develops after constant round up...My pencil is sharp... Premium on corn for it being non GMO is well worth the added chemical cost especially when the seed is cheaper to start with.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 10:06am
I plant Legend conventional corn and soybeans, I don't spray but I cultivate both 3 times per year. I have very few weeds but I do proper tillage and cultivation (timing is everything to prevent weeds). I'm not an organic farm but I raise natural feed for my chickens. Probably costs about the same to grow as it would to spray but I don't mind the extra time on the tractor.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 10:06am
With corn prices as cheap as they are I don't know of anyone using insecticide or fungiside around d here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 10:39am
K. But this post isn't the same as your last post, ie, there's a lot more to it than "non GMO seed is cheaper", and that's my point as well. Not sure about your 5% yield drag comment, but OK.
In fact, for GMO traits and yields, the BT trait has a far greater impact than chemical tolerance, and if you plant GMO corn, it keeps your options open.
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 11:18am
ACD21man,
I am considering going back to conventional corn next year on the 90 or so acres I plant. Over the past couple of years I have phased out the BT trait and am planting just the RR trait. I have my dealer put down RoundUp, Lumax, and extra atrazine at planting time in no till and rarely have to spray post emerge. Lumax is not cheap but there are many other options for corn sprays, including post emerge for both grass and broadleaves (at least here in Michigan)that are cost effective.
I have never heard of yield drag with RR corn personally.
As mentioned above you'll just have to pencil it out. With good weed control expect the same yield with RR vs. conventional. The seed I buy would be $30 less per unit than the RR, I would still be using the same herbicides, just no RR post emerge.
Edited by Ben (MI) - 19 Apr 2017 at 11:21am
Part time farming with a 1980 7060 and 1984 F3 hydro.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 11:21am
Neighbor plants Triple Stax but sprays conventionally so he has options. Besides having insect control is important. Sometimes folks forget you get paid per bushel not per acre.
Edited by victoryallis - 19 Apr 2017 at 11:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 11:28am
Exactly Mr. Victory. I've planted triple stax and sprayed conventional as well as I have a landlord with a "no roundup" rule. And it outperformed the conventional on the same land by tonnage (silage) and with a really sharp pencil, it was too close to call a winner.
This page was generated in 0.089 seconds.
