New ac owner with carb questions
lswat50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lswat50 Quote  Post ReplyReply Direct Link To This Post Topic: New ac owner with carb questions
    Posted: 17 Apr 2017 at 8:51pm
Have a 1942 allis b model with zenith 211954 carb. Anyways I took apart the front end and replaced the crank seal which went well. I decide to clean carb and the discharge jet broke on me. I've looked everywhere I can think to find it but this is unlike any jet I have found. Any help would be great as I'm down till I figure this out. Thanks for any help! I have pictures but not sure if they will post
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 8:57pm
Try to post pics. to give us an exact idea of the beast! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote lswat50 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 9:01pm
It keeps saying file to large. I'm not good with how to downsize for a forum post
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 4:19am
here is how I change picture size.
open paint on computer, go to file open, open the picture, then go to resize, at the top it will say percentage or pixels, click pixels, in the top box type 480, the bottom box should change automatically, click ok. then save and your done.
hope it helps, dt
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 6:02am
If you have Windows operating system you should be able to go into your pictures, right click on the picture and choose edit. at he top you choose resize. Chose pixels and change the top to 600 or something in that range and apply. When you X out it will change it to  that smaller size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lswat50 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 5:43pm
Hope this works!! I really need some help
Post Options Post Options   Thanks (0) Thanks(0)   Quote lswat50 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 8:04pm
I figured out the number for the carb is 211954. However the nozzle looks nothing like this one.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 8:30pm
Not sure exactly where you are. If its a Marvel Shebler carb, you may be able to find a kit at a tractor supply or Agri supply. I have had luck with those.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lswat50 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 9:26pm
It says zenith on the bowl but yea I can try tractor supply this weekend.
Rugerben View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rugerben Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 1:58pm
You can also check out any of the sponsors here.  Many have those parts available and entire rebuild kits for both the zenith and the marvel.  I rebuilt my card with a kit that included everythign and what a difference!  They also have many of those zenith parts on ebay.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 2:39pm
Call Sandy Lake, they are listed as sponsers
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 4:08pm
It is Zenith. It is a 67-267 main nozzle.   Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lswat50 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 7:04pm
I've looked through eBay and alot of other sources. Found bunches of the ones that are threaded below the hex but none on the other end as mine is. I'll keep hunting and thanks for pointers so far guys. Maybe I'm just missing somethin
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 8:29am
This site (link below) has a nice carburetor use chart.  The carb you have is listed as one for a model 60 combine.  Even if you are able to fine the nozzle that you have in your carb, it will be expensive.  An option is to buy a B core carburetor and put a kit in it.  I am sure some of the forum members will have used ones for sale.
http://www.thecarburetorshop.com/IndustrialkitsA.htm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 9:22am
I'd Just call Steve at (973)632-5596, he will fix you right up.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 10:14am
Yep, what Don said. Steve in New Jersey.
D17 Series 1
Allis B- 1939
Allis B- 1945
