180 Remote Hydraulic question
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Topic: 180 Remote Hydraulic question
    Posted: 16 Apr 2017 at 9:32pm
I've seen a lot of 100 series tractors with what appear to be dual hydraulic remote valves, but with only one pair of hose couplers on the back.  The second pair are plugged.  Can a second pair of couplers be added to these tractors for dual remotes, or is it not as simple as that?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 12:50am
It is that simple as long as the tractor has "3" hydraulic levers side by side. At time of delivery most AC tractors did not have remote couplers from factory; dealer / purchaser installed as needed.
IF you don't have a 3 spool valve and lines already to the plugged adapters you'll be needing to find some parts.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 6:09pm
A lot of tractors were ordered 'cheap' with one or as in this case 2 remotes with one side either a pipe plug female w/o breakaway  or with one breakaway and the other plugged.
Usually the LH couplers were used and the RH plugged.
There were several different type of breakaways offered down through the years. Some were kind of tough to hook up...
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 6:31pm
I know you are asking about a 180, but my 170 came with only one. It has been a lot of years since I did it, but I added a spool and the extra set of quick connects. It wasn't too hard and I got the parts from Cooks Tractor in Clinton, Mo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 8:10pm
Thanks for the help! The tractor I'm looking at has three levers and three valves in the stack, so it looks like it has what I'm looking for.
