Tractor " quiz" pg 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Tractor " quiz" pg 2
    Posted: 10 Apr 2017 at 6:23pm
Ok here goes page two. 7 through 12
7.   On the CA tractor the belt pulley is:
    ( ) a. Optional extra equipment.
    ( ) b. Not available .
    ( ) c. Standard equipment.
8.   The transmission clutch or hand clutch on the WD-45 tractor is:
    ( ) a. A single disc dry type clutch.
    ( ) b. A multiple disc wet type clutch.
    ( ) c. A single disc wet type clutch.
9.    The helical gear transmission in the WD-45 and CA tractors:
    ( ) a. Are commonly used in all makes of tractors.
    ( ) b. Has less tooth surface.
    ( ) c. Offers quit, long life operation.
10.    The hand clutch on the CA tractor:
    ( ) a. Stops forward travel and pto.
    ( ) b. Stops pto but not forward travel.
    ( ) c. Stops forward travel and let's pto continue to run.
11.    The model B. CA and WD-45 engines are built with:
    ( ) a. Dry sleeves.
    ( ) b. Removable wet cylinder sleeves.
    ( ) c. No sleeves or liners.
12.    The wide type rims used on the CA and WD-45 tractors give:
    ( ) a. More room for liquid ballast.
    ( ) b. Narrow bite.
    ( ).c. Faster ground speed.
There you guys go these are easy also
RickM(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:36pm
7.   a.  Optional extra equipment
8.   b.  A multiple disc wet clutch
9.   c.  Offers quiet long life operation
10.  c.  Stops forward travel and lets PTO continue to run
11.  b.  Removable wet cylinder sleeves
12.  a.  More room for liquid ballast
Missouri Allis Chalmers Club Member; 1954 WD45 (NF), 611LTD & 811GT Lawn Tractors
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:05pm
Number one - Standard Equipment
All CA's we sold came through with hydraulic and needed the pto belt pulley to operate.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:41am
Thanks Mike, this one was easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 4:06pm
Even though there easy, do you still want me to post them Ted.
You think there easy because it's info that's been around for sixty years but in 1959 was relatively new stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:45pm
Heck yes Mike....There are a LOT of young guys on here that will learn from them.
Actually, us older guys should hold off answering and see what the young'uns come up with.  Sound like a plan?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 10:41pm
Ok sounds good
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 6:10am
I missed #8 but got the rest
Edited by thendrix - 13 Apr 2017 at 6:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 6:20pm
Ok guys here's answers for these
7.    C. Standard equipment
8.    B. A multiple disc wet type clutch
9.    C. Offers quit, ling life operation.
10. C. Stops forward travel and let's pto continue to run.
11. B. removable wet cylinder liners.
12. A. More room for liquid ballast.
Edited by Mikez - 17 Apr 2017 at 6:21pm
