200 540/1000 pto
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 200 540/1000 pto
    Posted: 26 Mar 2017 at 9:20am
Have a 200 with 540 PTO only and wanted to switch to 540/1000 wondering what is needed to make the switch also will the 180/185/190 lift housings with 540/1000 work.
Bob J Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob J Wi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 10:31am
On our 200 I was told by our AC club member Pres.
that all I have to do is take out the bolts around
the shaft and pull out the PTO and install the opposite
end into the hole and reinstall the bolts. I have never
done it, so I cannot say for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 11:40am
Mine don't unbolt straight 540 from what I been told the gears are in the lift housing so just wondering if all I need is the lift housing and internal shaft or if there's gears up inside to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 3:28pm
Gear in torque tube to change also.    MACK
