CA stalls
coulter14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coulter14 Quote  Post ReplyReply Direct Link To This Post Topic: CA stalls
    Posted: 01 Mar 2017 at 3:02pm
My CA stalls with cultivator even in sand. Raise cultivator slightly and it starts moving but the cultivator is'nt deep enough to get the weeds. Is this a traction boost or clutch problem?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 3:09pm
If your hyd continues to work when it stalls, my guess is the hand clutch.
Leon B Mo
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 3:11pm
If your rear wheels aren't spinning - turning it would be main or hand clutch slipping? What's it do when you have it in gear, hold brakes and release clutch. It should kill engine.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 3:31pm
Sounds like its time to rebuild the hand clutch.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 3:46pm
I thought by stall he meant the engine dies, but it sounds like the hand clutch is slipping since he still has hydraulic power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 3:50pm
Stall, to me, is engine dying too.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 4:56pm
If it stalls under load ,probably fuel restriction , junk in bottom of tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 5:48pm
*Could* be the coil if it does it under load. I had that happen once on my 8N back in 2015. I was mowing a pasture, and as soon as I engaged the PTO and put a load on the engine, it would sputter and die. Ran fine going down the road, etc. I put a new coil in, and then I was back to brushhogging again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coulter14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 5:59pm
Engine runs fine. The tractor just stops moving. Never gave the hand clutch a thought.
