wanted: d10/12 grill guard pics
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: wanted: d10/12 grill guard pics
    Posted: 04 Jun 2010 at 4:12pm
Gonna have a guard made up for the ca. Looks like there were 3 different types made for the d10 12/ca. Can I get some pics to see which will work best on a ca. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 5:38am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 7:02am
I helped Tracey Martin so he could make some .Not sure if he is going to make any to sell .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 7:06am
Here is the one on my grandsons D-12
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 3:19pm
thanks fred, nice pic. Does anyone have the guard that bolts to the front casting? Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 8:18pm
Fred, I plan on making some to sell. Almost finished with the D15-17 grill guards. Been real busy with paying work this year. Tracy Martin
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:08pm
Ca Ron & Tracey,
It looks like that the steering arm on the CA may interfer with the grille guard that goes on the D-10 & D-12. How is that done differently?
DeWayne
Steve-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-KS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 10:02pm
Here are a few from my d10.  Hope it helps.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 11:52am
Steve where did you get yours? I was at the Gray Tn. GOTO and there were several like that on several different make of tractors.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:21pm
Dewayne, there should be enough clearance between the arm and the grille for a bracket. I have a model 8 loader on on this ca, so I think I will pattern the guard after the d10/12 guard that bolts onto the front casting. I can use the cultivator bosses on the ca casting, then run a bracket down to the side rails that mount the loader frames. Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:32pm
steve, the guard on your tractor looks pretty darn good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 10:07pm
CaRon, The diagram of the grill guard wouldn't work on a D10 or D12.The grill on a D10-12 is wider than the torque tube. The guard brackets have an offset in them.That way it can be fasten to tractor torque tube and front pivot bracket.That is the reason the guard is bolted together than welded. HTH Tracy Martin
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 5:57am
Tracy, Keep me in mind when you get the D15 series II done.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 9:46pm
Tracy, I did notice that about the brackets. The #8 loader side bars fasten to the torque tube/front pivot bracket making it a little wider than the grill. I'm thinking the straight guard brackets like in the diagram will fasten to the side bars with the sub frames. What are the grille guard densions? What size material is used for the guard and the brackets, if you don't mind me aking? I know a guy who knows a guy type of deal, is going to try to make me one. Any advice? Thanks Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 9:52pm
I meant to write, What are the dimensions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-KS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 10:20pm
Its been on the tractor ever since i can remember.  My granddad got the tractor back in 1966.  My uncle says he put the guard on because grandpa kept beating up the front end.  I'm assuming he got the guard from the same dealer he purchased the tractor from.  Here's a picture of her back in '72 resting by the bunk house.  I love this pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 7:23am
This is my new weight and grill guard that Snowman made.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 3:00pm
Dusty, looks good. Snowman did a nice job. I didn't realize he also made the weight. Sharp!
