d17 series 4
mlr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlr Quote  Post ReplyReply Direct Link To This Post Topic: d17 series 4
    Posted: 14 Nov 2016 at 8:12pm
I have a d17 that suddenly locked up with no warning. you could put in in reverse and go a few feet and then its just like you slammed on the brakes, put it forward and go a few feet, lock up etc. Took pans off of bull gears to see if any metal had falling in. One side had a few pieces of metal, very small, so I changed all the bearings and races. Put it back togeather and still the same. Jacked both rear wheels off ground so I could turn by hand and I had no problem turning wheels forward and backwards. Put tractor in different gears,still no problem turning by hand. Start up engine and put in gear a loud squelling sound and lock up, Put in reverse and a couple of minutes, lock up and vise versa. Even pulled tractor with truck with engine off and in gear, no problem. It has a lot of mechanics puzzled. Any ideas would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 9:19pm
If you put transmission in any gear and PD in neutral and let foot clutch out, what happens then?        MACK
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 7:34am
Brakes. MINE did same thing
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 10:51am
when you had it up off the ground and were turning the wheels by hand were they both going the same direction?
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:54pm
Here is a probable cause.
The PTO gears in this diagram are located in a compartment directly behind the hydraulic reservoir. These PTO gears turn even when the PTO is not engaged and are driven via an intermediate shaft and gear down from the main clutch shaft. They constantly turn when the main clutch is engaged and have been known to get damaged if tractor is used for heavy and ABRUPT brush hog use. An inspection of these gears can be made by removing the small oil pan aft of the hydraulic reservoir. Oil must be drained in both HYD and PD compartments prior to removal.
Edited by Macon Rounds - 15 Nov 2016 at 10:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:57pm
Here is a diagram of the intermediate shaft and gears, also the main clutch shaft and gears.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 5:47am
Ditto
There is a small spring that when in breaks will allows the brake to go to full lockup, it holds the brake disc together
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:50am
Just a thought because I'm not familiar with a D17, if it was the PTO gear, wouldn't it lock up or labor the engine regardless of the transmission? Seems like since it only happens when it's driving forward or backwards it's somewhere in the transmission or after, breaks would be after transmission also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:15pm
I agree. The brake issue is the most probable cause with the series 3 and 4's. However his initial comments did not indicate that just one side was locking up.
Sure wish this guy would chime back in. Need a little more info from him.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:43pm
He also said they pulled it with a truck with no problem.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:19pm
Yep. further confirms the brake issue. Same as when he had it jacked and turned the wheel freely. When the wheels drive the brake it drives the balls off the ramp. when the axles drive the brake it tends to drive the balls up the ramp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:28pm
wonder what area the squealing noise he mentioned was coming from ???
Marble17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marble17 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 9:16am
I hope you guys are still checking this post.... my series 4, 17 diesel did the same thing last night plowing my driveway. Please, any HELP.... mine was left side only, locks up both ways, happened on an uphill, could put it in a forward gear and hold right brake and it would "unlock" for a few feet then lock back up, after about 100 times doing that I got it 200' out of the driveway. Also witch is driving me even more crazy, the hydrolics are slow when it's locked up 3 point and loader. Please help, I'm stranded at 8,000ft and 6' of snow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marble17 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 9:33am
Sorry, also, this was doing this occasionally in reverse only, leading up to this, as soon as I put it in a forward gear it was fine, also the small spring on the front of the axle is there, is hooked up and has tension on it. Any help would be appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 8:03pm
Marble, I'm not an expert, but sounds like it could be a brake issue again. Probably something came apart and is hanging up
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 9:42am
If you had both wheels off the ground with it in gear running and it locked up its NOT brakes if one brake locked up pinion gear would just transfer power to the other wheel causing it to get faster if off the ground it dosent lock up slowly apply one brake at a time until one locks up and won't release. Buy the way do all these test setting in the seat with foot on clutch for safety and nobody in front or back of the tractor hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marble17 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 10:58am
Bradley, I have not had both wheels off the ground, but when the left side locked up, all power was to the right side. If/when the snow and Ice is gone, I'll get it towed UP to my house and test more.
