D 14 fluid leak
Paloma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paloma Quote  Post ReplyReply Direct Link To This Post Topic: D 14 fluid leak
    Posted: 29 May 2010 at 6:42am
Hello Members, I have a D 14 WF (#12399 - 1958) that is leaking transmission/hydrolic fluid from the final drive housing area under the seat.  I do have the service manual.  (1) Can the repair be done without specialized tools?  (2) Where is the blocking placed so the parts can be removed?  (3) Can both sides be worked on at once to compare wear & placement of parts?  (4) I'm not too much of a mechanic, but have done some repairs.  Is this a job for a professional?  Thanks for any responses, PCC
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:18am
Paloma
It sounds like the hydraulic hose to the rear lift arm piston is leaking. Not a difficult task as it goes from the transport valve to the piston(which is inside the pumkin. It is a good time to replace the cylinder seals at the same time. Replaced the one in my D15 myself with the aid of a cherry picker shop hoist a long time ago. Before you remove any bolts, drain the differential and hydraulic resevoir. I think you need to remove the brake linkage rods and the line at the transport valve that goes into the pumkin. Then remove the pumkin to expose the piston and remove it and replace the seals in the piston (available from any of the fine AGCO suppliers on this forum). I recommend that you also get the AGCO hose from them also, the Allis has a high pressure hydraulic system and most after market ones may not hold up...and the correct length is real important.
This page was generated in 0.049 seconds.
