Snap Coupler subsoiler questions
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: Snap Coupler subsoiler questions
    Posted: 23 Oct 2016 at 6:14pm
I mounted my snap coupler subsoiler today. Very dry here and I wanted to make the 45 bellow a little.
It looks like a #3 just based on a google image search.
Where the shank mounts to the beam, there is a couple of pieces mounted either side of the shank, that ride on top of the beam.   One of them has a couple empty holes in it.   There's an empty hole in the beam. What are these for?
There's also a loose fitting piece behind where the lift link arm is welded, looks like a piece of flat bar with a couple twists.
It doesn't suck down very deep - bottom of the shank gets level and rides on the furrow.
Pretty sure some stuff is missing... does it have a beaming adjustment to set the angle of the shank, and thus set running depth?
Also got the 45 hung in 1st gear... gotta pull the shift lever and get it back aligned.   The joys of 60+ year old stuff....
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 6:21pm
Have any pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 6:30pm
I need to learn how to post em.   Will get some tomorrow.
C w/ 3rd gear out
WD 45 wide front
bryani289swmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryani289swmi Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:21pm
Here's a picture. Thanks.
Bryan
Sticks and stones may break my bones but hollowpoints explode on impact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 11:40pm
If yours is like the one in pic,that screw needs shortened up to tilt the point down
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 10:11am
I think this is a #3.  I got it from bryani289swmi.  I still love it Bryan!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 10:41am
They will run deep if set right, here's Dave on his D17 at last year's plow day.
Michael Crowe on his WD45 K pulling a pin hitch unit.
I had my sub soiler behind Jerry's D14 running just as deep as the one's behind the bigger tractors, but I can't find a shot of him working it, sorry Jerry.
Edited by Don(MO) - 25 Oct 2016 at 10:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryani289swmi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 7:45pm
How weird this whole thing is. Brian F(IL) has the subsoiler I sold him. The one in the picture I posted first is of one I bought from Michael Crowe. I just got done using a different one tonight to subsoil up a couple acres, I bought that one at an auction in Indiana! I was subsoiling up a low spot in a bean field and didn't need the trash cutter as in the one I bought from Michael. This spring I hope to use the one pictured below, after I get it home. Thanks.
Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 2:48am
Yep, it's like Brian F's but has an extra part.
How is the angle set on this one?
I can see clearly on the screw type plow... not so much on this #3.
Thanks! I'll upload pics once I scale them down.
C w/ 3rd gear out
WD 45 wide front
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 5:18am
Looks to me like the sod cutter needs to come off as its only going as deep as the axle on the sod cutter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 5:20am
And if any of you fellows really want to make your Allis snort I have an old pull type
subsoiler that has about a 3 ft shank on it.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 5:37am
In the first picture up above, what is the part attached on the back side of the point for? Looks like it would be to open up a tunnel down there!
Edited by littlemarv - 29 Oct 2016 at 5:37am
The mechanic always wins.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 1:15pm
That is a mole that does leave a temporary drainage tube behind the subsoiler.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 8:00pm
In more than a few years dad used one with a mole to drain wet spots back in the ditch and rip a pass out through the wet spot and watch the water run for days and we also had a pipe that went in place of the mole and came up the back and out the top you could bury wire as fas as you could feed it in
CO2789 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CO2789 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 7:29am
Looking for a subsoiler, not too far from NW Indiana.
      Thanks
This page was generated in 0.146 seconds.
