190 gasser charging problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190 gasser charging problems
    Posted: 04 Jul 2016 at 11:25am
Have a 190 gasser in the shop that discharges all the time while running, it has a new Delco altenator on it ;; but ive looked at another one and it has a white plug off to the right side of the alt. ; the one that discharges doesn't have that plug of 2 wires,,,, anyone have this plug or any help
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 2:16pm
What voltage is measured on the battery while the engine is running?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 2:46pm
Is it a new internally regulated delco or an old original externally regulated one. An original will have a regulator under the hump just foward of the steering wheel. When you look at the alternator the plug will be two parallel spades in the plug. A new one will have two spades in line with each other. The new one will require rewriting to provide a sense line to activate it to charge and disconnect the regulator under the hump.
