greasing up the roto baler
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: greasing up the roto baler
    Posted: 22 Jun 2016 at 11:28pm
No question here, just some mindless jibber. Thinking while I was greasing, and greasing, and greasing...... (you get the point) the roto baler. The something like 48 grease zerks that it has; at least I think that that is what I read somewhere. I've tried counting them, but I lose count after 10, because that's when I run out of fingers. I think the thing is 10 pounds heavier after I get done greasing it. But any way, when you do the math on this, and take the roughly 77,000 roto balers that allis made, and take that times the 48 grease zerks per baler, that is just over 3.6 million grease zerks. And that is just roto balers. Think the all crops were pretty liberally grease zerked, too. I realize that is spread out over a few years, but man, how did they make that many grease zerks back then, and who screwed all of them in? Bet there was a big turnover in help in that department. I know I wouldn't last an hour being a grease zerk installer! LOL! Darrel
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 12:14am
now you is starting to think like me.....scary....ain't it?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 6:56am
Back before there was CNC there were automatic screw machines. The are marvels of mechanical automation. Here is one at work, not making grease fittings but similar dinky part. Machine shops would have rows of these and once set up to make a part they generally were not changed over due to the time required to do so.  They just shut them down until another run of that part was needed.
[TUBE]I9UCwntixPg[/TUBE]
Edited by Butch(OH) - 23 Jun 2016 at 7:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 7:02am
That didn't leave very many places to ware out.      MACK
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 8:10am
at least 2 would never take grease, the ones on the hay kicker in front of the big drum turning the belts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 8:33am
Darrell...you ain't spent time greasing anything until you've greased a 2MH corn picker!
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 1:18pm
I know you right Shameless. I don't remember for sure but the IH 1PR had 83 grease zerks or the big bin 66 had 83. I know it was a bunch, and I know in the morning it was time for the second cup of coffee when you got done greasing everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 2:34pm
yes, very scarey
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 5:31pm
The older stuff all needed greased a-lot. I grease this picker two times a-day that = two tubes of grease per day. Then grease the old two row corn binder two times a-day, it will go through three tubes per day.
The old IHC two row corn binder.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 9:16pm
      No Leon, the big bin has 78.     Duane
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
This page was generated in 0.110 seconds.
