Radiator hose
crich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crich Quote  Post ReplyReply Direct Link To This Post Topic: Radiator hose
    Posted: 02 Jun 2016 at 6:01pm
I'm embarrassed just posting this issue. I had my water pump re-built so I thought it would be a good idea to replace the bottom hose, 1-1/2" hose. I have tried two worm drive type hose clamps turned 180 degress from each other, T bolt clamp with a worm drive clamps and it still leaks. I sanded and filed the stub coming off the bottom of the water pump and tried gasket sealer, and I must of broken 5 worm drive clamps trying to get it tight enough. I'm at my wits end, any ideas I haven't thought of ? I was thinking the radiator hose I'm using is a little stiffer than the one I replaced? Thanks for any ideas. Clinton
Post Options Post Options   Thanks (0) Thanks(0)   Quote crich Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 6:06pm
BTW- I've researched new hoses on websites that have an I.D. dimension anywhere from 1.485"-1.158. Is that too little difference? Clinton
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 6:38pm
Just a thought ,its not your rebuilt pump leaking out the seal and running down your hose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote crich Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 6:47pm
No, that was the first thing I checked. Clinton
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 9:13pm
It may get better after a year. Mine did! Guess it has to rust the hose back onto the pump!:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 9:53pm
I agree with JPG AUSTRALIA. Water pump leaks.     MACK
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2016 at 8:16pm
How tight is the hose without a clamp? Those stiff radiator hoses don't just compress under the clamp they usually wrinkle up leaving a gap if they're much bigger than the pipe outlet. Get an OEM hose for your tractor that fits fairly tight or even stretches a bit without a clamp and line the inside where it seals with water pump and thermostat sealant, it will not leak guaranteed.
Edited by Bill_MN - 04 Jun 2016 at 8:17pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2016 at 10:51pm
Exactly!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 1:00am
if you really think it's the hose, then get a bit smaller hose, pull the tractor up to the house, put the hose in the microwave for a little bit, (this will soften it), run out the door and slide it on and let it cool by itself. it should shrink down tight as it cools, then snug up a hose clamp to it. chances are it'll still be leaking out the water pump!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 3:09pm
Someone drinking bathwater again Shameless !!!
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crich Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 4:56pm
I ordered a OEM hose, and clamps. I like the microwave idea. The hose should be in next week. I just had the water pump rebuilt, and I can see where the hose is leaking, before I even start the tractor, here's hoping it's not the water pump!  Thanks! Clinton
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 6:09pm
Fred...I've done that for years...works great with sprayer hoses too! don't always hafta do it that way, but sure is handy when you do!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 6:44pm
Hot water works to soften...and a little dish soap makes them slide on easier.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 7:09pm
For shameless people only!!!!   Hold hose in exhaust pipe of a warmed up machine,can be done in any old field.I get little done now,if I took everything home to micro wave I would never get anything done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 9:49pm
I gots a nuke machine in my shop, used just for stuff like this! it's the old one from the house after the old lady....ooops....I mean the loving wife decided we needed a newer/bigger one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 2:25pm
shameless ya ever throw in a hot pocket with your rad hose?? hehehe
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 5:22pm
If the hose slides over the pipe easy, it might not seal up for some time. Get one that won't quite fit. If you put a cup of cooking oil in the microwave and get it hot, then dip the hose in the oil, it will soften it and act as a lubricant too. I used the wife's temperature probe in the oil to get it hot enough when I had to put new seals on a hydraulic cylinder  Geek
Edited by CTuckerNWIL - 06 Jun 2016 at 5:24pm
