1930's Ford "Wide 5" on a 60!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: 1930's Ford "Wide 5" on a 60!
    Posted: 06 Feb 2016 at 9:31pm
Great granddad bought this All-Crop 60A new in '49. Somewhere between then and 1983 he had someone cut off the original hubs with bushings and weld on two 1930's Ford car "Wide 5" hubs and rims to the combine!
 Those things are pretty rare, aren't they???
Granddad told me that was a common thing to do, as welding on car hubs eliminated greasing the "troublesome" bushings.
Jason in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason in MO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 10:19pm
i wouldn't call those rims rare, Volkswagen used them up till around 1968. Rumor has it that they actually bought the dies from Ford in the late thirties
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 10:35pm
That's interesting. I wonder why they would do that, considering you can't use a tire machine to change the tires. Or at least, I don't think you can.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 1:06am
a lot of trailers today use that type of wheel...I steer away when I see them on trailers!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 9:50am
Creston, what diameter is that rim?  It appears to be a split rim with an outer removeable ring. The car wheels were all one piece. That one is either a truck rim or a military rim.
GaryL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 11:42am
VW ran wide-5s until 1967.  The ones in the picture Creston posted a bit different.  I know several other makes of vehicles ran wide-5s.
An adapter is needed for wide-5s.  About the only place that would be able to mount those rims is a shop that does RV tires.
Edited by GaryL - 07 Feb 2016 at 11:43am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 1:06pm
I think there are tire machines that support by the rim just inside the bead, rather than the center.
Balancing rims with the large bolt circle is most difficult. I've not found a tire shop with an adapter for balancing, so had to balance my flat bed trailer made from the frame of a '74 travel trailer by hand. With the wheel off the ground and the brakes backed off, I gave the wheel a spin and marked the top side where it stopped with chalk, and repeated several times. The wheels badly out of balance stopped about the same place every spin. I added weights on the top until the wheels stopped mostly randomly. Unfortunately used weights didn't stay on the rims very well on the road. That didn't take care of dynamic wobble unbalance but was a way to do a static balance. I found I had to mark the rims and the drums with paint because the drums were as much of a part of the lack of balance as the tires.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 1:24pm
I'll check the diameter this evening. Yes, it is a split rim. It could be military I suppose. Great granddad's brother was in the military and he brought home a lot of military stuff (Jerry cans, tools, tires, etc.) after he retired.
How do I remove the old tires from it? just cut them off? They're no good anyway.
Then the next question....how do I take the ring off? I watched a You tube video on how to mount a tire to a split rim, but they didn't say how to remove the ring.
Thanks!
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 2:59pm
do your self a favor and trow those rim away
and you will save someone live
The exploding components of a failed
multi-piece wheel assembly have earned
the nickname “widow makers.” Multi-piece
wheels are two or three piece assemblies
which require tube type tires. They are
much less common then single piece
wheels but can be found on garbage
 trucks or other heavy duty trucks.
These assemblies utilize a split ring which
secures the tire to the rim. The ring can
appear to be properly seated on the rim
prior to inflation when in fact it is not.
If inflation takes place while the ring is not
properly seated, the ring may suddenly
release. Inflation of these types of tires
must always be performed in a tire cage.
Unfortunately, explosive separation can
occur once the inflation process has been
completed and the tire/wheel assembly
is being mounted on the vehicle.
    B:-)       Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 3:19pm
"do your self a favor and trow those rim away
and you will save someone live"
THROW THEM IN THE JUNK PILE! They are just waiting for a chance to maim or kill someone.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 3:21pm
Check with your dirt track freinds the wide five is the standard you can fin just about any size rim , like stated above save lives and junk those rims also torch the ring in half before you junk them that way nobody can pick them up and reuse. The life you save me be a freind you just havent met yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 3:23pm
It usually takes a special rim iron to stretch the lock ring to get it on and off. I bought a set of tires for a '65 F350 dually close to 30 years ago. All the rims had the locking ring. Nobody in the tire shop would touch it but the boss and the 6 tires took all afternoon, the old ones didn't come off easily. I've never seen help in a tire shop do so much other work to avoid work in my life.
And the split rims, there are several types, have a reputation for decapitating people working on them, especially inflating without a good enough guard. And the guard suitable for a truck tire would not contain that car size rim parts. Maybe wrapping a tow chain around the tire and rim going through the center hole several times and locked to keep it from letting the ring loose would be good. There is a section in most Ag tire handbooks, like from Titan/goodyear on safety with multipiece rims. The last 20 pages of the current Titan/Goodyear Ag tire handbook talk about mounting and dismounting. The last 15 of those are about multipart rims.
http://www.titan-intl.com/files/Agriculture/Titan_Goodyear_Ag_Databook_2015.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 3:33pm
    B:-)       Dnoym
There's a reason why split rims are called "The Widow Maker".
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 4:29pm
yep...as all said above...gits rid of those rims...if the junk yard won't take them with the tires on...burn them some foggy dark night!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 4:34pm
They are 17" 11/16" in diameter.
Also, after some online searching, I found that a lot of people agree that they are safe if you do it right. Only if you don't is when things mess up.
Edited by CrestonM - 07 Feb 2016 at 4:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 4:48pm
Can I find these wide 5 rims that aren't a split design?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 4:58pm
Yes you can find them without split rims. I've mounted thousands of split rim tires and never had a problem. I really don't like the 3 piece rims. I once saw a cage after a ring came off. It would really make someone think twice about mounting them. I wonder if 9N Ford tractor wheels would fit on that hub??
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 5:01pm
Yes, I think so! If these are Ford wheels and hubs from the 30's, then yes, they are the same bolt pattern as a 9N/2N.
Wait...the 9N and 2N have 3.00x19 tires though. That wouldn't work for a 60 I don't think.
Your saying you've mounted thosands of split rims makes me feel a little better. Any advice on doing it safely and not having it explode on you?
Thanks
Edited by CrestonM - 07 Feb 2016 at 5:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 5:10pm
If I can find some old 1 piece rims I could do this...
Maybe I could convert it to 15" centers so I can use the old tires off my trailer! They're still good, but they were getting old and I didn't trust them running back and forth to the farm on the interstate.
Edited by CrestonM - 07 Feb 2016 at 5:11pm
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 5:31pm
Split rims aren't worth the trouble these days, but the real killers were the split center rims that used to be used on the five and six bolt wheels on 2ton trucks. IIRC the tire sizes were usually 7.50x20 or 8.25x20, there was absolutely no way to tell if they were together right or not.
The only common split rim that I am aware of that is still on the road today is the 10.00-20 mounted on Dayton wheels that is used on the container trailers.
For the OP: If in fact VW used this bolt pattern you should be able to find rims that are useable, there are still a lot of VW based dune buggies around and somebody has to be supplying wheels for them.
I would measure the bolt circle very carefully before spending money, I remember trying to use Ford car wheels on a 9N one time and they didn't fit. My forty year old memory says there was a size change in 1936 or so on the car wheels.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 6:08pm
You wouldn't believe how many wide-5 VW rims I tossed for scrap about six years ago.
Edited by GaryL - 07 Feb 2016 at 6:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 6:12pm
Darn!!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 7:19pm
how about ya just start all over ,,,. shoup sells spindles with hubs, cut those off and weld on new ones,, just like your Grandad did a long time ago... shoup, and prolly other farm stores have them or can get them,, that way you can use a standard 6 bolt implement rim and tires
when my Grandad ordered his 60,, he ordered it with Timken bearings, he said he wasn't going to put up with them bushings ya had to grease so often
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:26pm
Had a friend killed in 1991 by a split rim on a flatbed truck while he was adding air to a low tire. Nearly took his face completely off. 19 years old. The inside dual blew while he was inflating it and it caused the outside dual to blow off shearing the studs and sending the tire, rim and ring directly into his face, throwing him against a gas pump which was completely flattened by his body. Throw em away.
Wink
I am a Russian Bot
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:30pm
I'm not sure what that 2 piece wheel came off of, but 1937-1939 ford cars had wide five pattern one piece wheels. They would be 16" wheels, should be able to find some $50-$75 apiece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:30pm
Here's a thought...After I get the tires off, why can't I just weld the ring on and use it as a 1 piece rim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:38pm
Another idea...I have a junk 8N at the farm with good front hubs on it. Maybe I could remove those hubs and weld them on...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 10:12pm
The two piece rim does not have the dip in the middle, so you can't put a tire on it without breaking the cords in the beads then it won't hold air or stay on the rim. Go look at the last 20 pages of that Titan/Goodyear ag tire handbook I referenced. Look before the last 20 pages for information on rim shapes.
Gerald J.
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 10:31pm
if you lived closer i would show you the dent in the roof of my shop 24 feet up from the floor and let you speak with a friend of mine who brought over his split rims for help mounting. i done 2 of them and watched him do one and he done the other while i was outside. i heard a loud bang and alot of screaming. the ring was not set and came loose  i would say if it didnt hit his arm and break it that it might have killed him, or atleast went through my roof. i advise finding a set of vw rims at junkyard for next to nothing and saving yourself or someone else. if a split rim gets pulled flat i have heard old timers saying that them rings can come slinging off there.
shackratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2016 at 5:21am
Creston
take a look at these
http://www.ebay.com/itm/Real-deal-1950s-60s-dirt-track-stock-car-wheels-wide-5-Ford-15-Buick-rims-5-v8-/201515943071?hash=item2eeb49449f:g:e3cAAOSwL7VWsABT&vxp=mtr
AC 180, TO-20, Case 580B Case 450 dozer
