Plowing with a 7060
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Topic: Plowing with a 7060
    Posted: 07 Jan 2016 at 2:56pm
Hello,
I just bought a 7060, in good shape and only about 5,000 hrs on it. I would like to plow with the duals on---so I am looking at buying an IH 155 rollover plow.
However, I don't want to pull the guts out of this tractor! I farm in Southwestern Idaho--and the ground isn't too heavy. I would just rather be safe than sorry...the plow looks pretty heavy.
Any help would be appreciated!
Sincerely,
Brad
Caldwell Idaho
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 3:14pm
a 7060 will hardly know a 5 bottom plow is back there.  You will usually just run one dual on the unplowed left side so that the single rear tire on the right will be placed in the furrow.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 3:36pm
If you want to leave both duals on you need to find an on land plow, meaning that the whole tractor is out of the furrow.
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 4:27pm
We pulled 6-18 with our 7060 for years in central Indiana in the furrow
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:10pm
My neighbor back in the 80's pulled 6x20 IH plow with his 7040 PS. Pretty sure it was a 20" plow?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:18pm
We pulled 6-16 with our 7030 years ago...it was a load in heavy ground. We had it sitting at 175 hp...3 gear button down and every once in a while you would have to put it in 3 low so she could cool down
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:19pm
The plow I'm looking at is a flip plow. From what I understand...it is an on land plow. It seems fairly large and heavy. I worry my 7060 might not lift it enough to flip it around. I will try to post a picture of one like it.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 7:59pm
7060 should be a good piece of property to own. I love mine. it's a black belly powershift, what's yours? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 8:02pm
So its a fully mounted plow...I still don't know how you could pull it on land... Guess I'll need to see a picture of it...it will pull it just fine...how many horse is your 7060 ours dynoed out at 215
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 8:50pm
I pulled 5-16's with my 7010 for years in heavy bottom ground, with no problems. 3rd gear low side!
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:16pm
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:19pm
Shameless, was yours a flip bottom plow?
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:20pm
Darrel, mine is the same as yours..
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:21pm
I believe my 7060 is 160 horse..
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:23pm
With front weights you should be fine, the plow is big but there is a lot of air between the steel stuff.  My 8030 hardly knows there is a 4 bottom AC spinner on it except when it picks up the plow in sod.
Allis Express participant
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:39pm
Is an online easier on the tractor than an in furrow?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:48pm
Why do you want to run with duals all the way around?
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:52pm
Paco...no, mine was a semi mount furrow plow, on land and furrow pulls no different if tractor is set up right. on land is usually a bigger plow and allows the operator to plow with duals left on so you don't hafta mount and dismount the duals all the time (labor saver). you'll be fine with that plow pictured on your 7060! but do put front weights on it. (full set).
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 11:47pm
When I bought my 7060, I needed to plow some old alfalfa sod, so I hooked up my AC 6-16 plow,,,,,,,,,,,,, maybe it was a 2000 series. I dropped it in about 7-8 inches deep and started in. The tach went up and pegged, but it sounded like it might be pulling hard. I shifted up a gear and the same thing. I was in the nine mile per hour gear BEFORE the tach needle came off the stop! Of course the sod ribbon was being thrown about 3-4 feet, so I just dropped back to a normal gear!
That 7060 is more tractor than you think!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:12am
Definitely hang a full set of weights on it...even at 160hp you should pull it fine in 3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:21am
oh...and don't stop, then lift it out of the ground, lift it while in forward motion!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 6:14am
In furrow plows are easier to run a straight line.  Once you get a furrow started, you just drive your right side in it.  On land you have to keep an eye out to make sur eyou aren't wandering.
AaronSEIA
MUM FARMER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MUM FARMER Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 7:23am
I think the three point arms and linkage will in short time fail on the 7060 with that 5 bottom 155 it will pull it but you will break the hitch 4btm would be a better match rollover plows are very hard on the tractors   I have ih145 in furrow behind 8070 mfd and thats a nice match but a load on the 3pt
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 9:50am
There have been lots of 5 bottom on land rollover plows used on 7060's around here over the years with no problems, just be careful, it is a lot of weight back there.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:40am
I don't care the size of the tractor to the # of bottoms, sure a 7060 will pull 5 with no sweat. But I will never ever go back to a fully mounted, and doubly ditto so for a rollover. If you become stuck at all, game over!! To many surprise water holes in my ground.
carl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carl Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 12:49pm
In theory, you would think the onland would pull better, equal traction on both wheels, etc., but in practice the right wheel without a dual in the furrow works better.  Partly it's due to the center of tractor being closer to center of draft on the plow, and also the better traction of the furrow wheel I think.  When we got our 220 some years ago, we set it up for an on land hitch with duals, and went back to having the right wheel in the furrow.  Plus as noted it's much easier to keep going straight!
Paco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paco Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 9:15pm
Thanks fellas for the insight. I think I will stick to a 3 bottom. Plow I have and pull it behind my 1105 mf. It will take more time but maybe less hassle in the long run. Thanks again!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:13pm
Check to see if you can drop a bottom off of that plow....seems a lot of them are set up that way.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:46pm
Put the 7060 on the three bottom and pull it in 5 hi...that would be a sight to see
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 1:01pm
my 7060 pulled my old 6z16 melroe anchor fine with singles, no fluid, and IIRC only one extra set of wheel weights.   Going up hills in my sand would stop me though, 1FastHigh, and I'd drop it to 1HSlow but didn't have the weight and would spin out.
I only needed to break the land so I wasn't too worried about efficiency.
and I plowed horribly, but got a good kill regardless.
on the flat areas, I could have pulled in 2HF
for me, weight was the limiting factor, which surprised me, as the 7060 is almost double the weight of my Case930, and the 930 is rated at 6 bottoms. I doubt it would pull my 6z16 anchor though
AC7060Pd 1975
This page was generated in 0.108 seconds.
