Turn sighal switch 7020
leader58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Topic: Turn sighal switch 7020
    Posted: 09 Sep 2015 at 3:34pm
Can anyone tell me which wires go on which terminals? Turn signals work but 4 ways do not. Has a new nos switch. Thanks
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 3:38pm
it should be the regular light switch that's bad, not the turn signal switch. had that happen on my 7010 once!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2015 at 5:36pm
oh...and if you get a new one from AGCO, it'll come with an extra wire and some kinda silly instructions. I didn't use the extra wire when I replaced the switch and it has worked perfectly for past 10 years or so!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 6:49am
Is that switch different from a 7050 Shameless? I put a new one in a couple years ago but don't remember an extra wire.......but I don't remember a lot of things.
Say, did you find that coulter blade?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 9:36am
Lonn...my light switch is on the right side of the steering wheel, the turn signal switch is on the left side of my steering wheel....dunno if the older maroon belly tractors are the same? and no...haven't been able to walk out to check for the blade...and what another said about using a disk blade sounds like a good idea too! just hafta blow a few holes in one and bolt it up tight! sounds like a cheap fix! even if you hafta use a new blade.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2015 at 10:35am
I do have some old but good 19" blades from a Miller disk. You know that might be worth a try.
Wink
I am a Russian Bot
