WD45 PTO
Isonm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 PTO
    Posted: 02 Aug 2015 at 10:36am
PTO on my wd45 will not disengage.  Any suggestions on how to fix and what may cause this.
dads45
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 11:06am
Is the set screw tight down at the end of the rod lever?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 12:13pm
If it's not the set screw or external linkage then it's internal to the PTO drop box. You will need to drain the fluid and then unbolt the drive shaft then remove the bolts holding the drop box in place.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 12:15pm
Yes it is tight to the shaft and not slipping.
dads45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Isonm Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 12:19pm
Thanks.  I figured I would have to open it up but thought maybe there may be another way to a fix.
dads45
