O/C sprayer help needed
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: O/C sprayer help needed
    Posted: 11 Jun 2015 at 12:07pm
I have a 32B Deere sprayer that hasn't been used in years and all the hoses and fittings and well pretty much everything thats not metal or fiberglass has deteriorated. I'm replacing all plumbing fittings valves and roller pump. It has 2 fittings on bottom of tank one for suction and the other goes where? Is it a return line? Also does it need something to control pressure? This is all new to me so any pictures or help is greatly appreciated.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 2:48pm
usually a return line for when you shut off the pump on field ends and for agitating your mixture! be sure to price everything you need before you replace everything. this will get expensive real fast, and you can usually buy a working sprayer cheaper! when I replaced the nozzels and drops on my hagie sprayer that came to over $600.
