AC D21 KeySwitch Plate
DMOSS1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMOSS1 Quote  Post ReplyReply Direct Link To This Post Topic: AC D21 KeySwitch Plate
    Posted: 30 Apr 2015 at 2:33pm
I have a D21 that I need the instruction plate that goes behind the key switch. If anyone has one or knows where I may get one, please contact me or reply on this post.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2015 at 10:40pm
Steiner's carries them.  Some of the vendors here might as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMOSS1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 4:40pm
Thanks DSeries4 I checked with Steiner and looked in their catalog and
I could not find it. If you know the part # that would be great. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 10:45pm
ACS354 - Switch plate $16.95
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2015 at 3:14pm
that acs354 isnt the correct switch plate for a 21, a 21 uses the d series switch and the others that this fits uses the indak style,
But as far as I am aware this is the only one that is available and you could use it if you cut the hole out in this switch plate as it will be hidden behind the escutchin or however you spell it,  will be hidden by the chrome nut dealee that holds the key switch solid
Edited by dustinmo - 03 May 2015 at 3:15pm
This page was generated in 0.085 seconds.
