Todays project.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: Todays project.
    Posted: 15 Oct 2016 at 8:28pm
I would like to be combining beans or be done with them and do corn. But since central Iowa has turned into lower Unkton, (any Married With Children fans), had to work on other things.
This is one of my 'long term projects'. I bought a pair of 15x28" rim 'blanks'  last spring. I have lots of junk rims with good rails and two good pairs of 16.9x28 Firestone Field and road tires. One pair on JD (titan) rims, the other on very narrow (10"?) spin out rims.
The blanks.
Today's work.
The rails cut out of a junk rim.
The plan is to get the rails cleaned up and welded in the blanks. Would be nice to get them galvanized.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:08am
Looks like a good project. I'd be know I'd screw up the alignment or welding of the rails if I tried that. I bet you've got it covered though. Looks like a good way to reuse some steel and save a little money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 8:42am
Sundays victim, I think Red Green himself may have owned the tractor these rims came off of.
What it was reduced down to.
I kept 5 of the pieces to make rim patches out of. This rim was in better shape than the first one, it all went in the scrap pile.
Hockeygoon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeygoon Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 9:25am
That actually looked like it was a pretty good rim.
I just "resectioned" a rusty rim. I cut out a chunk 10" wide and 44" long and then cut the same section out of a donor from a Ford NAA (with its own rusted out valve stem hole) and after much grinding mated and welded the two sections.
Its mate needs a section 49" long cut out of it - not enough left of the donor rim to fix it too. Back to advertising on Craigs list.
Can you use those rails from a narrower rim on a wider rim?
Edited by Hockeygoon - 17 Oct 2016 at 9:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 1:27pm
This rim was better than the first one but still very rusty. That's why it didn't bother me to cut it up and save what I could.
I'm pretty sure the rails will work in the wider rims but will do some more research before proceeding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 10:29am
Slowly making progress on this. I cleaned up 4 of the rails Friday, off work until January 3, will see how far I get. One thing I did find out is that the rails are specific to rim width. The ones I have came out of 11" rims, they will work, just won't be able to spin in or out 2".
I'm leaning toward centering them in the blanks, could offset to one side. If anyone has a compelling argument for one or the other let's hear it.
I want to get these galvanized when done but if that doesn't happen being ready for paint will be a good thing.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 10:38am
That is a nice indoor project for the holidays!  Wish I had more time off for things like that.  Hope to do a bit of work on the 190XT today and tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 5:51pm
Off work this week and too warm to hunt deer so making some headway on this. I did quite a bit of math trying to figure out the spacing on the rails and apparently my math skills aren't what they used to be. So I had to go to a time honored method, trial and error. Rails tacked in place.
I cut the center out of a wheel center for this job, it worked well. Lots lighter and being able to reach through easily helped a bunch. The center part that bolts to the axle will be used for a puller project in the future hopefully.
This is the fancy gauge I made to lay out the rails. A piece of tig-welding rod cut to length. That's where the trial and error came in.
Today I welded the ends of the rails but did not work on the middles, need a pair of deep-throat vice-grip welding clamp pliers. After that they should be ready for galvanizing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 7:14pm
Boy that's a lot of work Mike.  But it looks like you've got it all figured out and in hand.  Amazing how much you lose through the years.........and geometry was one of my BEST classes.  I've retained a lot, but it's because I still use it a lot.  It's the lesser things that we forget.
As far as where they should go.........I'd go with having them be able to go OUT as far as possible, not centered.  Stability is everything.  BUT, if you had to go with rows, distance, etal...... then who knows.  What if you cut them apart and added a piece in so it would go the whole rim width?  Cut each beam so the added piece is in a different spot so there wouldn't be any real serious stress problems?  Just an idea.........
Looks like a good COLD winter project though......... have fun with it and stay warm and safe and see what you can do...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 8:02pm
Man you have a LOT of patience and skill ! A 'tip of the hat' to you !!
When I was cleaning up a combine rim for the D-14 , I built a silly, simple jig to spin the rim.
Think of two  12" long rollers about 1 foot apart , mounted in some wood pieces. The rim spins on the rollers making it easy to clean and paint the rim..
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 8:18pm
WD-D17 were three different widths....same rails just positioned "centered".For that wide of rim,you probably need to keep them close to the one edge and let the excess hang out.That way you can suck em all the way in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 10:12am
Ted, while I don't use math nearly as much as I used to I think getting accurate measurements may have been the problem. The math wasn't that complicated and I have a great calculator.
Jay, that's a great idea on the roller setup.
Steve, I decided to center the rails, gave serious thought to moving them to one side. With them centered it will make the narrowest setting 4" wider.
This has been a fun and interesting project. Like many of the things I start it turned into more work than expected. Would I do this again? Not sure, the 15" blanks were not to expensive and new 15" spin-outs aren't cheap, so maybe. Thanks for all the comments, Mike.
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 7:05pm
I didn't use any math at all, just laid then and used wheel to get proper spacing, tightened them up and welded first end , shifted wheel in ,welded other end and did same for middles. no clamps needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 7:10pm
That's a good idea Don. Setting the center in the middle of the rails and tightening the locks will do a better job than the welding clamp would.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2017 at 8:27am
I'm bringing this back to the top as I have finished welding the rails in and have applied a coat of primer on the wheels. Decided not to galvanize. hopefully get some paint on them soon. Will try to post some pics soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 9:43am
I was making good progress on this but planting season got here and I've slowed back to a snails pace. The current weather isn't helping either. I have got some primer and paint on them, wanted to galvanize but went the simple route.
I did get started wire brushing one wheel center but probably won't get them painted until after the beans are in the ground. Since I just bought a different planter it is hogging all my free time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 9:16am
Not sure who posted the tip about using a handy-man jack for a bead breaker, but it worked like a charm. At the current rate I'm making progress I should have these tires on the tractor by 2025.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 9:25am
You do high quality work. Kudos to you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 9:34am
Thanks Stan. I intended to post a few more pics but photobucket is not cooperating right now. Maybe later tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 9:49am
Got photobucket to cooperate finally. Metal prep is the most tedious part of working on these old girls to me. pays dividends in the long run though. Thought a nice pair of centers was a must for new wheels and tires.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 6:49am
Looking good.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 10:15am
Wow, nice work!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 1:09pm
This was a good weekend foe 'today's project'. It really turned into my ongoing project.
Got the second tire dismounted from the yellow rim and mounted both on the new spin-outs. This was a warm fuzzy feeling, bought the tires about 4 years ago.
Took a few shots for size comparison. These are 16.8x28's on 15" rims compared to 14.9x28 on 12" rims.
13.6x28 on 10" or 11" rim.
These are 16.9x28's on 13" rims, look almost the same height to me.
And finally the tractor these tires are going on, these are 15x26 same as 18.4, they are good tires but non spin-out rims and no provision for wheel weights.
Speaking of wheel weights, I've had this pair of Oxnard weights for a couple of years now. When I get them cleaned up and painted they are going on. Then it will be time to start working on the front of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 10:36am
Well it seems photobucket has ruined my thread and I assume all the others I've posted along with a lot of others.
I got the centers assembled and mounted on the tractor yesterday, have pics, haven't figured out how to post them yet.
