Thicker Viscosity oil for GM ENGINES ??? |
Author | ||||||||||||||||||
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85571 |
![]() ![]() ![]() ![]() ![]() Posted: Yesterday at 4:28pm |
A dealer bulletin obtained by GM-Trucks forum users, all affected units (MY2021-2024) are currently up for recall, including those in the inventory units. While the dealer bulletin only contains instructions for the dealers that will work on the trucks, GM has confirmed in a statement that it will be issuing a voluntary recall "to address this matter as quickly as possible."
There's A Remedy For Those That Pass Dealer InspectionsFor the uninitiated, the L87 V8's woes lie in the connecting rod and/or crankshaft components in affected vehicles having unspecified manufacturing defects. When these components fail, it could lead to loss of propulsion or complete engine failure, which can be hazardous or even life-threatening if they occur while in transit. We've found several cases of this issue before, with some instances happening while on the highway, while others reportedly bombing as early as 4 miles. 2:GM has provided a remedy for the problem, although it's incomplete for now. The recalled vehicles will be checked by the dealers for diagnostic trouble code P0016. If it's not set, the vehicle in question passes the inspection but will have its oil replaced by 0W-40 high viscosity oil (replacing the former 0W-20). It will also be given a new oil filter and oil fill cap that reflects the change, as well as a section in the owner's manual for the new oil type. According to the documents shared, the thicker oil "offers an increased further level of protection." Engine Replacements Could Happen, But...On the other hand, those vehicles that will not pass the inspection will be "quarantined" and should not be sold/delivered to the customer. It's unclear what will happen to these vehicles, with the documents only stating that "Additional information will be provided by General Motors in the near future." Edited by steve(ill) - Yesterday at 4:31pm |
Sponsored Links | ||||||||||||||||||
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8186 |
Wont help the lifter failures, did they ever recall that?
--- but if it has not failed yet, they will put 40 wt oil in place of the 20 wt ..????
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3561 |
God bless those engineers.
