Series 50? model 53 plow |
Brad1 ![]() Bronze Level ![]() Joined: 7 hours 34 minutes ago Location: Sparta MI Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 3 hours 60 minutes ago at 11:36am |
Hello all, I'm new to plowing, I did send for a user manual from eBay. A model 53 I believe is what I have, some advice about the traction control and not flipping the plow over and onto myself would be appreciated. D15, the right-hand speed control lever is not working at this time but will be splitting it open for repair this winter. I do brush hog with it and all the snap coupling hardware is in place as far as I can tell. Searching the net for a vid showing a snap coup 3 bottom install on a D15 and what is needed and what to look/watch out for is nonexistent. Maybe someone could point me in the right direction. Trying to navigate the unofficial Allis page is difficult for me, the FAQ page isnt any help either.
DanielW ![]() Silver Level ![]() Joined: 19 Sep 2022 Location: Ontario Points: 222 |
Not sure I'm fully understanding all your questions, but here are my thoughts for what they count:
i) "Not flipping the plow onto yourself" - not sure what you mean here. Are you worried the traction booster operation might somehow cause grief and rolling the tractor? You don't have to worry about that. At least, not as it relates to your plow/tractor setup. On our really steep side hills, plowing is one of our most dangerous tasks, because driving with the downhill wheel in the dead furrow means you're that much closer to tipping. I've gone up on two wheels in the air a few times, but haven't tipped/rolled yet. But this is nothing to do with the tractor/plow and 99% of people would never have this problem. It's just the way our land is. ii) RH lever is the traction booster lever. When you say, 'splitting it open", do you mean splitting the tractor? Or just disassembling the valve(s)? You certainly don't have to split the tractor (or, at least, not unless something pretty drastic is wrong). It's likely just a stuck traction booster spool/cam. Some penetrating oil, tapping the spool when removing the rear valve cap, and working it a bit is usually all that's required. Other folks on here willl be able to help you better - it's been years since I've unstuck one. But it certainly wasn't a big deal. This isn't a 'speed control' lever. It's to adjust the amount of the plow weight the rear end of the tractor carries to help it power through tough spots. Your wheel RPM stays the same, it just helps it not slip so much. I could get into a long explanation here, but do some googling of ''Traction Booster' and 'Draft Control', and you'll find a lot of videos explaining it. Nothing to do with speed (or at least, not 'directly' relating to speed). All to do with slip. iii) Post some pics of the plow and the rear-end/coupler of your tractor and folks here will be able to guide you in the right direction. I'll caution you, however, that a three-furrow plow may be one heck of a load for a D15. That completely depends on soil type and terrain, of course. I've seen several videos of D17's pulling four-bottom plows just dandy. But always in clean stubble on loose, black topsoil. On tough land and/or sod, it's a different story. I have a 180 which, seems to have quite a bit of jam - even for a 65 HP tractor (it doesn't feel anything running a 4X5 round baler up and down our hills). But a 3X16 plow in sod and our soil will bring it to its knees. First gear 90% of the time, and even then you can spend a fair amount of time with your front end in the air, just trying to plow 6" deep. You may therefore find you want to drop a bottom from your three-furrow for your D15 to be comfortable. Not worth worrying about immediately, but keep it in mind as something you may have to do.
Edited by DanielW - 2 hours 10 minutes ago at 1:26pm |
Hey, thank you for your quick response and sharing your experience. No. I've seen pics of a WD? with the plow flipped over and onto the operator, is that a WD issue? can this happen with the snap coupler and D15? No2, the long handle on the right was stuck, then smoke came out from around the lever I was told, so it burned up a brass bushing? I've read a splitting is in order. The two levers to left of the steering wheel do work I was told but will read up on their function as I do have a tractor operator manual. I can raise and lower the lift arms. No.3, yes, dropping one plow may be necessary. There are 2 broken 3/8'' roll pins one for each side of the lift clevis and cannot find any info for its purpose or how they could be damaged. I got the broken pins out, but should I replace them? I've also read online that there is a dedicated forum for just plow talk.
Also, I would really like to post a few pics but I have no idea how that would work. Maybe I can ask a 10-year-old for help. FAQ page is not clear on pic posting and I'm not familiar with techy jargon.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1323 |
I too have seen pictures of this, and I recently read a long thread on another forum about this very thing; there was lots of name-calling and insults that didn't accomplish much. Full disclosure: I have never plowed with a snap coupler tractor, but if I do I will definitely attach a chain to the front of the plow beam and connect it to something solid. I also wear a belt AND suspenders
