pictures of your wc..
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Topic: pictures of your wc..
    Posted: 04 Apr 2011 at 7:58pm
hello i would like to see picture of your allis chalmers wc's
here is mine
not perfect but im about to start sanding.
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:16pm
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:41pm
1941 As she sits waiting for daddy to return from Deployment!
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 9:56pm
This was 2009 at the Orange Spectacular:
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 10:01pm
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 11:26pm
Here's my WC Ole' Hercule's when I first purchased him bout' 6 years ago. When this pic was taken, I already had the sheet metal removed and started to work on his engine. Last Fall, I started back on the ole' boy again getting the grille, tank, and other sheet metal pieces done at the body shop. Just recently purchased a set of new fenders from my pal Tony C. and sent them to the body shop with the other pieces for a squirt of PO#1. Plans are to have him back together and rollin' this summer! Well, that's the plan anyway....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 11:39pm
A pic of Herc's engine going together from last summer. Everything all sandblasted and in primer now. Takes me a while to get my projects together with my full time job and part time business work load. Hopefully, this summer I'll get enough time to finish him up. Then its back onto finishing the resto on the Model G.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 5:37pm
What's that plate on the side of the block, Steve?
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 5:53pm
The WC/WD blocks have that plate behind the oil filter/mag, that's the easiest way to tell if your WD45 has the right motor in it because they don't have that plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 5:57pm
Thank you, Lonnie. I should have phrased my question better. It looks to me like a fabricated flat steel piece rather than original, but then I get lost when I look at anything bigger than a B. The plate just looked fabricated to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 6:04pm
They do look homemade I guess, they are just flat steel with some holes drilled in it, nothing fancy.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 9:01pm
Guess I will not get a fine for posting this .It is a WC Maintainer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 9:10pm
I was wondering where your maintainer picture was Fred, you show off, that is one great looking tractor.
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 10:06pm
thats not the "correct" color is it fred? good looking tractor it just doesnt appear to be original color.
Edited by abbaschild95 - 05 Apr 2011 at 10:09pm
Great-granfather's WC---- hopefully many more to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 10:08pm
my current project!
myallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote myallis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 10:12pm
This page was generated in 0.069 seconds.
