OK, '53 CA compression check
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: OK, '53 CA compression check
    Posted: 04 May 2019 at 4:30pm
130/160, 80/100, 75/85, and 140/150 or 160 I forgot to write that one down
I'm not concerned about the dry/wet values, but what are the odds the no 2 and 3 issue is a head gasket?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 5:44pm
Odds are real good....Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 6:23pm
well, that would make me very happy if that is all it is
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 6:26pm
I hope its not a crack in the top of the block, that has eroded...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 7:00pm
well, that is my concern too! although, I don't see any oil in the antifreeze, or visaversa. we shall soon see, I'll pull the head when it quits raining
Wait for the Lord;
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 8:47pm
If it is a head gasket you most likely have other problems that would cause it. These are not prone to head gasket problems if properly torqued.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 9:47pm
ya, that's what I suspect, but was hoping something simple. I'll know when it stops raining, I have an open air garage!
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 11:21am
Same here on the open air work shop. Not because I don't have buildings. They are so full I can hardly walk thru.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:53pm
well, good news, the block is happy, no cracks in web between 2 and 3.
gasket also intact. exhaust valve in no 2 cracked. so far, no obvious reason for low compression on no 3, but the lights were growing dim quickly in my open air garage , so I'll pick up tomorrow, weather permitting.
question, is the head o a C the same as on the CA?
Wait for the Lord;
