‘Nother Water Question
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: ‘Nother Water Question
    Posted: 16 hours 4 minutes ago at 7:07pm
Soooo… it’s recommended that the air pressure in the bladder tank be set 2-3 psi lower than cut on pressure.
Water at dad’s was acting up. Biggest problem turned out to be the sense line to the switch was plugged. Anyway for thoroughness I replaced the pressure switch. Guess I bought a lower pressure setting. I bought a 30-50. When the switch kicks on bladder tank pressure is about 35.
It seems to be working fine and cycling normally with a steady flow of water. So, ??? Should I put a 40-60 on it? It doesn’t seem to be broke so I tend to not wanna fix it!    Got plenty of other things to do.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 50 minutes ago at 12:21am
My Daddy taught me the hard way if it aint broke dont fix it
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 5 minutes ago at 6:06am
Sometimes it creates a problem where there wasn't one before.
