Need HB112 pics
KS Husker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KS Husker Quote  Post ReplyReply Direct Link To This Post Topic: Need HB112 pics
    Posted: 28 Feb 2011 at 3:32pm
Starting to work on my HB-112 garden tractor. Have seat pan off a B-112. It appears to be the same. I am missing the hitch and lift arm assembly. According to parts book it is not the same as a B-112. Does anyone have good pictures of the hitch and seat mounting brackets on a HB? Or an extra hitch off a HB? I believe I can make new ones if I had some good pics.
Thanks for the help.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 4:02pm
When sorted out, I have 2 rear-end assy's out in barn with some rear hitch parts on them if needed. They are not HB's that I know, may not work that said
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:25pm
heres a picture of my HB112, but I didn't know there was a difference in the HB & B . I'll have to take a look at mine . I also have a B112. so I'll have to look at them both & see if their different, But not tonite!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:58pm
Don't pull that 5020 too fast with that HB-112 without putting it in the tow poison or it will burn the bearings out of the top shaft; that's right out of the operator's manual. lol
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:28am
I have a B212 with the variable speed it has a solid rod for the lift and I believe that hydo's have a cable for the lift. I think the difference in the bracket is were the cable verses rod hook to it.
B212,716,two 314H's,WC,WD,D19,190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 5:22pm
well I looked today and there fairly simular the HB seems to have more arc in the rod. my b112 has a cobbled rod on it that somebody made, alot of extra bends that I can't see a function for It has hydralic lift on it.My simplicity & B110 have rods alike. there just straight. where as the HB 112 rod is arched upward but look the same other than how there bent. the 1st pics are HB112 ,The 2nd 2 pics are B112 & the last IS same vintage 12hp simplicity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KS Husker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 8:13am
Not sure why but can't see the pictures. I have the lift rod on mine. Missing the hitch assembly and what I would call the top link where the pipe goes in to lift attachments.
