model 80 sickle bearings
newbewd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote newbewd45 Quote  Post ReplyReply Direct Link To This Post Topic: model 80 sickle bearings
    Posted: 05 Jun 2010 at 1:51pm
Hello everyone.  A ol allis man that I came across has a snap coupler model 80 sickle for sale.  He says I can have it as is for $60-70.   The problem is that it is at his other farm and he believes the two bearings where the sickle board meets the body may be froze.  I am sorry I do not know what these are called.  His neighbor has one also that they are froze on.  I may be able to get one of these very cheap if I can find the bearings for one.  Any help would be great.  Thank you.
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 12:06am
If they are the same as a #7 mower, then they are not available through AGCO. The local bearing distributor also said they were discontinued. The number of the bearing is KP8, which is a bearing commonly used in the aircraft industry. I found 4 bearings for my #7 mower online from a place in Calif. They weren't cheap (but when restoring old tractors, nothings cheap, right?). They were about $35.00 a piece. I'm sure someone on here would know if the connecting link bearings are the same between a #7 & #80 mower.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 6:29am
I have a #80 parts mower.
Don
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 12:33am
 Hi  Newbe.. both sets of those bearings are available, the 2 that are on the crossbar (the bar the knifehead attaches to)  You need to go to your local bearing suppler to get them.. Part # 6304 2RSJEM ,these are made by SKF Explorer, they are about $60.00 a piece.  The other two which are on the connecting rods ( these rods connect  the crossbar to the flywheel ) Part # KP8FS428 these are made by ITM Industrial Tectonics. these two are a lot cheaper.  HTH    John
jeff77indy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff77indy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 11:58am
I bought some from I belive Aircraft Spruce for a n 82T a while back. I will check when I get home tonight if I still have their web address.
They are air craft control plane bearings.
Jeff
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 12:37pm
#7 mowers and early 80r mowers have different bearings, crossbars and connecting rods.  The later movers have a cast iron cover over the bearings with and grease zerk.  the #7s have a sealed bearing with no cover, Im thinking these are the ones that are hard to aquire. HTH
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 1:35pm
Here is a link for Aircraft Spruce.
http://www.aircraftspruce.com/menus/ap/bearings.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 12:35am
  Check the serial # which is located on the top right of the main frame. Prior to serial # R-6101 then it would use the bearing that I mentioned in a few posts back, but if it's newer then it might take different ones. Also, if you can check and see if the crossbar bearings have a bearing cap with a grease serk then it'l be after serial #R-6101.  HTH  John
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 10:03am
Where is the serial number located on an 80T mower?
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 5:12pm
The older model model 7 mowers use a KP6 bearing. newer 7's and 80's use the KP8.  Best source I've found is Aircraft Spruce: https://www.aircraftspruce.com/catalog/appages/kpbrng.php
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 9:02pm
 Serial # for 80-T could be on the tounge or frame just by looking at the picture, not for sure though....
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 9:09pm
Thanks John.  I will give it another look see when it is daylight.   I looked earlier today but had no luck.
