Looking for Hd6 part
Jgriffis03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Hd6 part
    Posted: 18 Mar 2026 at 9:42pm
I’m needing the intermediate shifting shaft. If anyone has one for sale I would greatly appreciate it. Number 5 on the callout for parts diagram of the shift tower. Thank you in advance
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 7:20am
Have made that exact part a couple of times in the past. 4140, or 4340 Alloy steel will offer enough surface "toughness" without heat treat to last. Have a machinist bore the shift handle, (#6) round and bush this with oilight bronze, or drill and tap your new shaft, (pivot pin) for a grease zerk, and cross drill for grease path keeping it tended to. While the shift lever is out always a good idea to have the lands where the pivot screws butt against cleaned up also. Makes for a nice tight shifter again as long as the shifting forks and shafts are in good condition. These always need touched up also as wear items.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:31am
 What’s the part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:45am
I’m sorry all, it’s number 6 on the callout.
P/N: 098089
Or
P/N: 086705
It’s the whole lower shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:46am
The whole shift lever is missing haha. My issue is that I’m not sure I can get one machined without precise measurements of one first.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 3:07pm
Maybe check with General Gear and Machine in Boise, Idaho
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 5:35pm
Definitely be cheaper to obtain used, but I can make one if needed.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:20pm
How much would you charge for one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:59pm
I checked there and they said the one they had they just threw out because it was worn out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 11:15pm
Forum member gemdozer has some parts but he said his yard is closed until Spring, also, he is in Canada
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 4:09am
No real idea as time and materials would be in play. Realistically probably $350 - $400 is in the ballpark. I have a good piece/pattern to follow. Have never made one complete as you need but have rebuilt several.
Before putting much into this tractor I'd suggest you manually get into each gear and operate it. You can do this by moving the shift forks with a pry.
Seen a lot of 'Starry Eyed" auction, and sale  purchases over the years reveal underlying buget busting problems underneath requiring wheelbarrows rather than shovelfulls of money to fill the pit.
Edited by Codger - 20 Mar 2026 at 4:54am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 9:16am
Little back story here, it was parked up about 40 years ago and I bought it for 600 bucks and I honestly didn’t have the equipment to pull it out of there so as the mechanic I am I got it running an drove it out of the hole it was stuck in. The only thing I need to do now is replace some hydraulic lines and free up steering clutches. I did try and shift in all the gears hand itinerary shifts pretty smooth and they all grab
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 1:05pm
I should have this lever shift and I could check late next week
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 1:59pm
Yeah I’d sure appreciate it. Really out of options at this point
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 2:39pm
Dont have the parts list handy - is that the part that fits into shift tower and has shift lever clamp to it ?
 The part that actually moves the shift rails in trany - ball type end and , pivot point center and round shaft through shift boot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 2:52pm
Yes, its the lower shaft that actually sit inside the transmission and has a big oval hole through it which is where the bushing goes. I will see if i can add a picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 2:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 3:14pm
My PDF version of the HD5/6 transmission parts book shows that as being called the "LEVER, shift" and is P/N 7086705.
I put about 40 hours into rebuilding that part on my Son-in-laws HD5G, mostly by brazing and hand filing; I documented it on a thread several years ago. It would be quite a challenge to fabricate one from scratch.
The intermediate shaft is something else entirely.
Best wishes on your project Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 5:45pm
Hopefully Gemdozer has what you need to get you going. Glad you know the trans and finals are good. Seen plenty that haven't been so happy once they break into them.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 10:44am
I rebuilt that part by machining a new #5 part , then machining #8 bolt to fit into #5 , next replaced roll pin that goes through #5 to a larger pin and cut 2 slots in it to fit end of #8 which holds pin from moving = the actual shifter casting #6 was drilled to accept larger pin . the tension on the pin is controlled by installing washers on #8 to set depth it indexes into the pin .
 It removed all slop from shift lever and is positive shift now with no odd movement . I also welded up the ball end of the shaft and reground it to the flat sides increasing size to fit better into shift rails. Made a big difference in positive shift .
Edited by Coke-in-MN - 23 Mar 2026 at 10:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 10:52am
Do you need the part or just need to rebuild yours ?
I might have one but not reworked - out of old HD5B transmission that had single speed reverse - but same as later units
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 10:57am
I do not have the part at all. Ill take whatever i can get, worn out or not
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 7:47am
I check yesterday for the HD6 shifter lever transmission and have one if it is not to late
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 3:41pm
how much would that cost?
