locking fuel cap
allis converted View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Topic: locking fuel cap
    Posted: 24 Jun 2011 at 9:50pm
Hello does any one know where I can find a locking fuel cap for a 190xt? I just filled it up and somehow over night it used over forty gallons magically. The local parts guys keep scratching there heads trying to cross it over to something else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 9:54pm
Sounds like you need a junk yard dog, but don't we all. It don't say much for our society now days.
Edited by CTuckerNWIL - 24 Jun 2011 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 9:57pm
I'd have better luck chaining the old lady out side than the lazy old coon dog!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2011 at 11:11pm
bump
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:04am
well just throw the old lady out side and bring the allis inside.. lol their problem solved
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:19am
If you do lock the cap can they just disconnect the fuel line and drain it anyways?
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 7:56am
Your best bet is fuel it only as you need. Yes, it's good to fill it when you're done for the day, but if some low life is going to steal the fuel, doesn't do your wallet much good. Just have to drain any water off more often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:41am
My neighbor drained the tank on his 4020 unhooked the fuel line and filled the tank with water it was pretty easy to figure out who was stealing his fuel. He tried a locking cap first but a slide hammer made short work of that.
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:52am
its too much work to go into the top of the tank and then siphon it out. its alot easier to unscrew a fuel line and let it run out. that's what they do to our tractors. It doesn't even help to padlock the door to the building we keep them in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 8:58am
This the second time they got me, last winter someone packed 45 gallons off in cans 3/8 of a mile walk from the nearest road in 18" of snow  if they needed it that bad I would have just gave them some all they had to do was ask.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 12:11pm
If the tank isn't full, they can't steal what isn't there...
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 1:02pm
It sounds to me like a midnight shift with a 12 ga is in order. Either that or run a hidden wire from your hottest constant charge fence charger to the tractor. The rubber tires won't ground it out, but wait till they try to get your gas then!
Edited by Protrucker - 25 Jun 2011 at 1:03pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 1:15pm
Not so sure on the 12, but I do know a lot of people are using those trail cameras.  Put them someplace where they can't be seen, but close enough to have good resolution of who is doing the work.  Quick call to the local police with the pictures should help fix the problem.
AaronSEIA
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 2:37pm
The locking cap probably won't vent either so the tractor will only run in 15 minute bursts with it in place.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 2:45pm
i agree get the 12 gauge out ant sit on the tractor and wait for them... if it is in the shed leave the doors open and wait....  also have the cops on speed dial!!!
oh and the ambulance
for them!!!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 3:36pm
I'd set up the trail-cam, but also set up a motion sensor (just the sensor) on a box about waist-high, looking towards the tractor, kinda upwards... and hook it up to a small light shining towards the house.  When you see the light go on, it's time to take a walk with the Mossberg and cellphone.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 10:38am
On my Case 930 I got one from Advance Auto.   Take your cap in and have them match it.  They are pretty standard.  I was more worried about someone putting something in the tank than taking it out.
Okiejohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okiejohn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 12:48pm
I'd put out a BIG sign outside the place where my tractor is, saying Warning, to whoever is taking my fuel. I am sitting out here with a loaded 12 gauge shotgun, loaded with 00 buck on some nights. YOU PICK THE NIGHT YOU FEEL LUCKY!
Be sure you are right, then go ahead.--Davy Crockett
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis converted Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 1:35pm
Well some one is sore today last night after I finished bush hogging I parked the tractor next to our sewage lagoon and wrapped about six runns of barb wire around it and then went to the loader end about dark and tied my coon hound up then I sat on my porch with my browning humpback, about eleven thirty I heard people talking they had made it all the way to the fuel tank and I fired two shots in the air then the dog started barking one of them got caught in the wire the other one tried to run and fell in the sewage lagoon then he must have climbed out and gotten hung up in the fence on the RR ride of way. This morning I found a ripped pair of jeans with some blood on them the dog was chewing on it, I walked the tracks and found a muddy cowboy boot. Hopefully they won't be back again.
