IB PTO leak |
Freewheeling ![]() Bronze Level ![]() ![]() Joined: 05 Nov 2017 Location: Wisconsin Points: 162 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jun 2025 at 10:05pm |
I have a oil leak from the PTO that appeared to be from the bottm retainer bolt hole. I discovered that the idiot previous owner used 3 different length bolts and two of them were worn 1/4" + below the head including the bottom one. The two retainer holes the crap bolts were in (top & bottom) were out of round and the faces were ground down. The mating housing hole for the bottm bolt was sloppy when threaded. Of course there are high spots by the retainer bolt holes. There were 5 shims between the retainer and the housing and a gasket between the shims and housing but none between the retainer and the shims. The shaft has some small dings and scratches that I [polished out. The seal looks OK but is some off-brand so I'll repkace it. Does anyone have a nice retainer (part # 207617)? Should there be a gasket between the retainer and the shims? My book doesn't show one. What's the process for the shims? It appars that National 50135 seal would be correct. Yes? Thanks.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5034 |
I believe that I have a NOS part that you need. However 207617 is not a correct part number for anything related to an IB. Could you post a picture of the part you are wanting?
I have a hard time using this site. I uploaded the photo but I couldn't shrink iot to fit the page. ????
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86793 |
your photos need to be a bout 800 x 600 pixels.. Most cameras are 5000 x 4000 or so... It is BEST to shrink the photo on computer in PAINT and THEN UPLOAD... if your using a phone, ... email to yourself, then RESIZE the photo prior to download..
I'd have to shrink the photo so I'd prefer to email it to you if you would. Mine is fsterzen15@gmail.com. I'm pretty sure it's the same part on the B,C,& IB. What makes you think they are different?
