Hyrdaulic lift allis G
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Topic: Hyrdaulic lift allis G
    Posted: 21 Oct 2010 at 8:16am
Hey Where do I get parts for my G? I mean what "color" dealer carries allis chalmers?
I need to rebuild the hydraulic lift cylinder on one of my G's... Also at some point I want to freshen the brakes and clutches on both G's
Thanks
Jonathan
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:20am
Agco.
Baum Hydraulics www.baumhydraulics.com carries a large variety of cylinder seals and may have them for the G.
Gerald J.
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:23am
Jonathan,
I might be able to help you out with the brake pieces.  The G I am parting out has practially new brakes on it and everything looks to be in good shape.  Let me check into them if you want and I will get back with you if you are interested.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 11:31am
Try some of the vendors here on this site. I know OKtractor might have some as well as Tony Carbaugh, and maybe a few others. AGCO, like everything else, most likely has them over-priced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 5:25pm
If the G cylinders are like the B's  and C's, there is nothing but a bronze sleeve and a chevron packing inside the gland. There is no piston or rings. Chevron packings and bronze bushings are available from Motion Industries and hydraulic supply places. Here is a website listing chevron packings. http://www.alleghenyyork.com/vee.asp
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:18pm
   we have brake parts etc.    1-800-254-3116   can help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 10:28am
TTT getting ready to ship my second G to Oregon, I'm sending the one with hydraulics, and I just took the lift cylinder off, and I'm about to take her apart... :)
Which set of threads should I unscrew? There is the sleeve right by the end that the ram comes out of (female threads), then there is the "tube" (male at both ends) then there is the base "sleeve" with female threads that the hose screws into...
Thanks!
Jonathan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 10:42am
The sleeve that the ram comes out of has to come apart to get at the packing. The packing gland has to come off to remove the rod from the gland because there is a snap ring on the bottom of the rod.
This page was generated in 0.161 seconds.
