Home heat oil stove |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8755 |
Topic: Home heat oil stovePosted: 26 Dec 2025 at 11:19am |
I've got an old Monogram oil stove that was used for home heating. Has a reastat run fan built in to oil flow control. Just lately has started to lose fan speed after an hour or so running. Visual inspection of reastat and electronic spray cleaning hasn't changed anything. Fan spins freely and have oiled it to boot. Is it the fan motor dieing or reastat failing? Have owned it 50 yrs. I suppose a voltage check out of reastat is what i need as it just starts slowing down. Shut it down for a while and it works again. Don't know what to do. Used to heat my shop. Any ideas? TIA that fan has alot of hours on it. How would a pro diagnose it?
Joined: 11 Sep 2009 Location: illinois Points: 89291 |
Posted: 26 Dec 2025 at 1:06pm |
i would bypass the thermostat.. Run power straight to the fan and let it run wide open all day long... Would be a good test to determine if the motor has a problem... Old windings could be breaking down when hot, or bearing could be expanding with heat and causing a little drag...
SteveM C/IL
Posted: 26 Dec 2025 at 1:38pm |
Yeah i wonder if it has brushes. Need to try your suggestion first before tearing into. I don't understand why stuff don't last forever......
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8299 |
Posted: 26 Dec 2025 at 6:12pm |
Are you using ‘electric motor oil’?
SteveM C/IL
Posted: 26 Dec 2025 at 6:32pm |
It is "3 in 1" oil. Isn't that correct?
Lars(wi)
Posted: 26 Dec 2025 at 7:04pm |
3 IN 1 is good for door hinges, bicycle chains, etc. There is specialized oil, for electric motor bearings. I do believe the makers of 3 IN 1 do market a specialized grade of lubricant oil, with ‘For Electric Motors’ printed in bold lettering on the front of their little cans.
Walker
Posted: 26 Dec 2025 at 9:10pm |
Go to a Hobby Shop and get some of the stuff they use on model RC airplanes and car motors. It made me a believer on a grandfathers clock works that refused to run on 3 in 1 oil. More reastats that came to me ailing needed to be cleaned or replaced, more than oiled.
SteveM C/IL
Posted: 26 Dec 2025 at 11:05pm |
I washed down the reastat coil with electrical contact cleaner. Didn't oil it.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34944 |
Posted: 21 hours 33 minutes ago at 4:13am |
Main issue is time on rheostats. Moisture and/or damp air to being close to the higher heat of a machine or furnace having ill effects on moisture delivers really foul corrosion or in air mineral buildup. At the nuke on a number of the oldest systems we actually had instructions to periodically ‘Wipe’ the system rheostats to burnish the buildup of corrosion or mineral deposits off.
SteveM C/IL
Posted: 11 hours 5 minutes ago at 2:41pm |
IR gun says 150 deg middle of motor housing after 25 min run time. I would think that is bad. Little ole motor has Little load on it. Heat off just fan running.
Edited by SteveM C/IL - 11 hours 4 minutes ago at 2:42pm |
DMiller
Posted: 9 hours 47 minutes ago at 3:59pm |
90, maybe 100F, chances are has lost winding varnish integrity.
SteveM C/IL
Posted: 5 hours 52 minutes ago at 7:54pm |
I'm going to see if i can find a replacement. Have good picture of tag on phone.
SteveM C/IL
Posted: 1 hour 60 minutes ago at 11:46pm |
Not alot of success finding motor. 1475 rpm 115V .35amp continues duty 60CY,protector 67A45. I'm not much for electronics. Can you use a rheastat on any single speed motor to trim it down on rpm without harming motor? Does it require a "special" kind of motor?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42107 |
Posted: 1 hour 35 minutes ago at 12:11am |
