Here's my plan for wiring the CA
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: Here's my plan for wiring the CA
    Posted: 14 Mar 2026 at 3:16pm
Any thoughts or advice...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 4:58pm
I would just get a wiring harness from "The Brillman Co." Www.brillman.com Just tell them when ordering what alternator you wish to use and it will be plug and play. There's no need to make it any more complex than it needs to be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 7:23pm
print looks good.. I think you got it....... I did the same thing 20 years ago... Made up 5 harnesses for "B" tractors...but i have toggle switch to turn ON.. then push button to START.... used them all.. Thumbs Up
Companies charge $160. just for the WIRES... then you need the switches and fuses if any.  Cost is minimal if you got the understanding of electricity..
Edited by steve(ill) - 14 Mar 2026 at 7:27pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 8:25pm
Anyone who will put that much effort into a schematic will have no problem building a first-class harness. Big smile
I usually roll my own, but had Grandson do the wiring on the CA last year just for the education. Materials are getting quite spendy nowadays.
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:27am
I wire all my tractors similar to this, 5 ACs, 4 Fords, 2 Farmalls, no factory harnesses. Troubleshooting should be easy, if they ever fail me....every one is 12 volt negative ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:49am
well, since you asked....
1) remove one of the fusible links in the alt-bat feed
2) install a +-40 amp ammeter
3) replace 10SI with the smaller CS-130 series or a Denso unit
4) install a 4 place fuse block instead of the  'power ' fusible link
5) one color per function
6) crimp,solder, heat shrink all end connectors
Edited by jaybmiller - Yesterday at 7:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:17am
Good points to consider.Smile
I much prefer a voltmeter rather than an ammeter, but I am too much of a cheapskate to remove a functional ammeter Tongue
I am not a fan of fusible links.
The 10SI alternator is indeed a tight fit on a Model CA as there is not much room for adjustment next to the steering arm, but it can be made to work so long as the adjustable pulley on the water pump isn't rusted tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:45am
voltmeter can lie, only shows the potential or possible energy
 whereas
an ammeter ACTUALLY shows electrons moving in and out of the battery.
'they' went from ammeters to voltmeters as a cheap cheat.. as they're easier to intall( cheap and universal).
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 44 minutes ago at 6:44am
The Brillman wiring harnesses are nice but do not offer the options that I want, plus I like to upgrade the wire sizes. I do like their Cotton braided spooled wire options.
I Probably will go with fuses rather than links, I like the "sealed" blade style fuses.
I prefer a voltmeter over an ammeter for safety, ease of wiring, more compatible with an alternator. I just want to know if the battery is charged/charging.
I already have a 10 SI that barely clears, when I need a new one I'll probably go with a CS – 121 it's even smaller than the 130.
Do you all usually run 2AWG battery cables as an upgrade for 12 V?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 8 minutes ago at 7:20am
If you were to call John and discuss you desires, he nearly makes all of his wiring harness to order and as I said to begin with he can customize a harness to your needs.
 i-888-274-5562
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 54 minutes ago at 7:34am
It might be worth checking with Steve at B and B Custom Circuits for a harness.
